Question about Laser Office Equipment & Supplies
School Mate SC-5050 CD player is making a thumping/skipping noise. Plays some of the CD and then stops. Same with multiple CDs.
I've tried cleaning the laser - no change. Needed for a 1st grade class asap.. Any ideas?
ice man
  • 68 Answers
SOURCE: Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting might need some cleaning of its it and check it out. good luck
Posted on Apr 25, 2007
  • 4234 Answers
SOURCE: cd skips
If the unit continues to skip after cleanig the lens using a cotton swab and alcohol, the optics are failing and need to be replaced. These units use Sony optics (KSS-213C I think) and are readily available for $25 or so. Any service shop should be able to replace this for under $100 total.
Posted on Mar 18, 2008
  • 15 Answers
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Posted on Jun 24, 2008
SOURCE: numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Posted on Oct 17, 2008
Sorry , not worth the hassle , bin it and get a better system second hand for around £25
Posted on Jan 26, 2009
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
Our church has a Phillips 760 cd recorder. We bought it slightly used ( or so we were told) and at first it was ok... Finicky with usable CDs, but ok. But now after a few months of use, it will start to...
try buying optical clean for the cd play run it few time before you do any thing else, make sure you buy one that has media disc cleaning fluid. put few drop of liquid on each pad push play, fast forward, stop reverse forward, stop few times, let it run until it stops. you mite find it at walmart but you may have to go dvd or record store, radio shack may also have it
thank you rod
Feb 28, 2015 | Audio Players & Recorders
I have a kenwood multiple cd player dr350 and it won't play cds
Kenwood multiple cd player dr350 draw and cd player has stopped working draw is stuck in and cd player does not work and the skip disc doesn't go round either.
Sep 21, 2013 | Audio Players & Recorders
Cds won't play
OK, your discription of your problem is rather vague.
Do they try to play but skip or make god awful noises? Or do you have no audio at all?
If they are skipping check to make sure there are no smudges on the underside of the CD. If so clean them with a soft cloth,
Sometimes severe scratches can cas the same problem. You can buff out some scratched using tooth paste or you can by a scratch remover that they sell in stores (it is a gadget that will clean and buff out some scratches available in many stores).
If you have any of the label missing then this is a worse issue. It is actually the top of a CD that you need to be most careful about scratching because if you remove the laquer that protects the silver layer of the CD it will remove part of the silver with it along with any audio or data that is on it. There is no repair for this.
If you have ruled out a damaged or dirty CD then be sure you are not trying to play a CD that has data files intended for computers on a player that cannot open them. The best way to do this is to check the CD on a computer and open the drive folder and view the contents of the disk. Files such as MP3, WAV, WMA and others will not play on a standard CD player. If the files are CDA that is a standard audio CD formatting. So next see if the disk plays on the computer.
If the CD plays on a computer then return to the CD player and attemp playing again. Make sure that the player recognizes the CD being in the tray. Also, verify, if you can that the CD is spinning within the player when you play. If the CD is not spinning or the player does not recognize rge disk try a disk you know to be undamaged.
If you still have problems then you will have to have your player repaired or replace it.
Sep 12, 2012 | Audio Players & Recorders
Technics SC -HD 501 CD jumping and skipping
If this happens on all CDs then most like the drive is bad or lens is dirty You can try cleaning out the heads using a cleaner disc. If you have a way to get to the lens you can try cleaning it manually. But most likely. It's one of the following dirty lens, bad motor, bad speed control.
Nov 16, 2011 | Audio Players & Recorders
Hello, I have a Technics HiFi system - I've had it for 10 years. The problem is that the CD player skips and jumps. I've tried cleaning the CDs but there are no scratches on them. I've also...
Its time to replace the optical unit ( lens ) of the CD player. Brace yourself the unit on some of those old players can cost more than a new DVD player.
Jun 02, 2011 | Audio Players & Recorders
I have a panasonic stero 5 cd system. model sc-ak44 after moving and plugging it in, the cd player just does not play. the flashing light says no cd when in fact there is a cd in there. it is put in the...
It's possible the laser assembly got damaged or dirty.. Inside the back cover of your users manual is a procedure to protect against that. Trying to clean the laser yourself would possibly lead to more damage as they are protected from view even when the units outer cover are off. I no longer actively repair electronics, but I can tell you a repair costs more after a customer attempt at correction than the original failure. Lasers are finely positioned mechanisms. I would suggest professional service.
Nov 25, 2017 | Panasonic SC-AK44 CD Shelf System
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
