I have a pl200 label printer, the screen is upside down, and the words are backwards. it just started doing this. any help will be apprciated
Inky
  • 691 Answers
SOURCE: Labels jammed in Laser Printer
Well i hope you don't need to get a technician out to remove those labels for you. If you do then you better have the coffee and biscuits ready to keep him appeased!!
The most likely place for them to have come off the page is at the first place the paper bends much more than about 45 degrees. If not there, then any other bend of similar angle. After this you will need to be looking in the fuser unit (the unit that gets hot) and the heat softens the glue on the label and they peel off.
Download a service manual form here to help you get it apart without braking anything!
http://www.tradebit.com/filedetail.php/4018886-Documents-eBooks-Technical
For future reference, please ensure that any labels you print are designed specifically for laser printers and the margin from the top of the page to the first label is as big as possible - preferably about 10mm or more.
Posted on Sep 19, 2008
SOURCE: Printer labels do not line
The only way I could get round it was to type one page of the labels, then print on plain paper. Check with label size then go back to screen and individually change the labels that were misaligned. Then when I printed on to a label page it was correct. Time consuming but at least I didn't waste any labels that way, only paper.
Posted on Nov 22, 2008
  • 62 Answers
SOURCE: Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
Posted on Nov 20, 2009
  • 2072 Answers
SOURCE: I have a Xerox 7655 printer and I am trying to use
You may need to change the driver. I have seen different issues with machins printing tabs, that changing the print driver will solve. Most of the tab issues are when the driver is a PCL 5 or PCL 6 driver. Switching to a PS driver frequently helps resolve those issues.
The newest drivers would be located on Xerox.com. Go to the home page, select Drivers and downloads, then enter your model number in the search box, and then select downloads and drivers again and select the newest PS driver and install that. I am pretty sure a new fresh PS driver will resolve your problem.
I am including the setup procedure below, I assume this it the process you followed.
Try a new driver. If that doesn't resolve it, possibly the machine firmware itself will need to be updated to the newest version.
The template is set up to provide centered text in the available tab printing area at each position.
At each printing position click to highlight all the text visible on the sheet. Type in the wording you desire and proceed to the next sheet.
When printing the file ignore the warning about margins.
At The Printer:
1) Load the tabs long edge feed with the smooth edge feeding into the machine. The first tab will be on top towards the front of the printer.
2) Set the paper type to [Pre-cut tabs (106-176gsm).
3) Set the number in sequence using the [up/down] arrows for the number of tabs in the set.
4) Set the paper size to [9x11].
5) Select [Confirm].
At The Workstation:
1) Select [File], [Print] and select your printer from the [Printer Name] drop down.
2) Select the [Pages] radio button and set the page range to 2-6.
3) Select the [Paper/Output] tab.
4) Select the [Select Paper] button.
5) Select [Pre-cut tabs] from the [Type] drop down.
6) Set the number in sequence using the [up/down] arrows for the number of tabs in the set.
7) Select the [Layout/Watermark] tab.
8) Select [Fit to New Paper size] and select [9x11] from the drop down.
9) Select [Rotated Landscape] from the [Image orientation] drop down.
10) Select [Ok] twice to print the job.
Posted on Jan 14, 2010
  • 254 Answers
SOURCE: Our thermal label printer Zebra
That means that your settings are wrong or the commands are not transmitted.
You are probably in inline mode try to switch to page mode
Posted on Aug 16, 2011
My labels are coming out upside down and backwards
Are you using a label printer like Brother QL 500 or something similar? If you are, there is a printer setting which probably is set to mirror printing.
Nov 23, 2017 | Office Equipment & Supplies
Brother p touch 1100/1800
Often a label printer sticks after a lot of use, especially if you have had a jam. Remove labels and preferably with a vaccum cleaner clean out any dust and bits left in. Turn it upside down and try again.
Then try printing a 'blank label' with no labels in and see if the motor starts. There may be a sensor that prevents this - if so clean sensor
Mar 08, 2014 | Office Equipment & Supplies
My machine just started printing upside down and backwards. What would cause this and how do I fix it?
It seems the respective settings were selected. You can re-set the pritner by removing the batteries and pressing On/Off 20 times.
Sep 13, 2011 | Dymo LetraTag QX50 Thermal Label Printer
My lg rumor screen flipped upside down and the words are now backwards. How do you fix it?
my cellphone word upside down its hard to read. i dont know how to fix pls help me out. thanks
Jul 21, 2011 | LG RUMOR Cellular Phone
The words on the label print out upside down.
You can re-set the printer by pressing On/Off 20 times with batteries removed.
May 15, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Image is upside down and words backwards
malfunction in the camera and will need repair
olympusamerica.com/repair
Oct 17, 2008 | Olympus FE-210 Digital Camera
Monitor 2 - Image is upside down and backwards
Check your graphic card settings. I have a 6600gt, and can invert my screen. Try going: right click your desktop, select properties. Go the settings tab. Clieck advanced. There do you have a tab for your graphics card? Mine shows I have a 6600Gt. After selecting the tab it displays options. I have NVrotate. That rotates my screen.
Jul 16, 2008 | Computers & Internet
Top screen
This is very unusual and I've never come across it. I can only think there has been some type of software corruption as you can not put the screen in backwards or upside down.
Jun 09, 2008 | Nintendo DS Lite Console
Upside down characters
Silly question - are you holding it the right way up?
If you are, there may be a display setting for rotation.
Jan 28, 2008 | Nintendo DS Lite Console
My Screen is upside down and the words are backwards
The first thing I would do is a reset. Read your manual about this process, which often requires pressing two buttons at the same time or take your batteries out, wait a minute and put them back. See if resetting helps. Not being familiar with your camera, speciffically, Ithis sounds like the firmware in the camera is reading the info back to you backwards when it processes the image (from memory) for you to view. That means it is the firmware in the camera that is defective and sometimes you can update or reinstall that. I would check the manufacturer's site for updates or recalls and if it is under warranty, send it back to be fixed.
Jan 28, 2007 | Fuji FinePix A120 Digital Camera
35 people viewed this question
k24674
jasbo
jasbo
