Question about Miscellaneous
I'm repairing a bathroom marble countertop as it is scratched & dull
I have a repair for the scratches but I need advice on a finish coat that has a sheen to it Need a good sheenshiney finish for the cover coat
  • 833 Answers
SOURCE: repair scratches on black door front
Mr....other than repainting, the only suggestion I have is one of those scratch repair kits that they sell at Pep Boys. The finish materials...paints...not stainless...are about the same as used on cars. Use a soft lambswool bonnet buffer and go slow.
If it is stainless...use 00 steel wool in a one directional sweep with a little bit of light oil.
good luck, sir.
Posted on Dec 03, 2007
  • 135 Answers
SOURCE: thick plastic film covering glass screen got deeply scratched while moving
Hi there!
I would simply replace the plastic sheeting. Will certainly be cheaper than replacing a tube. Glass tvs don't normally come with this plastic so leave it off if you can remove it. There is a type of spray on the market for this purpose, just don't know if available in your country. Please note: It is dangerous to use a tv which had been scratched beyond 1.5mm, The glass may become unstable and implode if bumped by accident. Good Luck,JUS004
Posted on Mar 09, 2008
krihard
  • 407 Answers
SOURCE: Nokia glass screen scratched
yes,
you change your scratched screen near nokia vender.....
Posted on Apr 10, 2008
  • 1019 Answers
SOURCE: Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
Posted on May 30, 2009
  • 382 Answers
SOURCE: I need to repair a scratch on my panasonic 42
It is glass but it may have a treatment on the surface, typically cleaning it will help. Buff with a microfiber cloth.
Posted on Jan 01, 2010
How do i repair an aqua brass bathroom faucet made of brushed nickel it has deep scratces on it
Scratches are probably caused by a cleaner with heavy grit such as Ajax. Using a cleaner with smaller softer grit will not cause the heavy scratching. You won't actually be able to fill the scratches but could give the faucet a "brushed" finish by using a mild abrasive such as peanut shucks or ground walnut shells mixed with a soft soap. Look to manufacturer for recommended cleaning.
Dec 30, 2014 | Plumbing
How can you remove scratches from eyeglass lens?
I'm afraid not. the light modern glasses, have a coating, trying to remove a scratch will remove the coating, and change the correct focus on that part of the lens. If the scratch is in the visible part, do you see a dull part, I'm afraid you have to buy a new glass. If it is not visible for you, try to live with it, till you need a new pair.
May 15, 2014 | Cameras
I have dark scratches on a white countertop. Soap and water doesn't remove it
bathroom cleaner let it soak (foaming preferred)
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_66344e9ad974c715
Jul 12, 2013 | Building Materials
How do I repair cat scratches from my leather furniture.
Here is alink to a guide for repairing cat scratches on leather furniture. But it's agood idea to also invest in a scratching post, so your cat leaves yourfurniture alone in future.http://www.cozycatfurniture.com/gift_certificate.html
Jul 23, 2012 | Cats
Ps3 scratched my game i think
Go to CDFixers.com. They will professionally refinish your disc for $1.95 and it will look brand new. Good luck!
May 02, 2010 | Sony Playstation 3 (PS3) Console
Cant find a teflon repair spray product
No product of this kind available. Pans are made to be used with plastic utensils so you don't scratch coating off, once you scratch coating of the pans they need to be replaced. I would not use them anymore, every time coating scratches off you are eating it. Who knows how bad this could before you, no one tells us this.
Mar 30, 2010 | Grilling
Scratch on the front panel, how do we repair. Does it have to be replaced?
Scratches aren't an easy or inexpensive fix. However, if, like most appliances, your's has a protective clear coat on it, you can try using a small applicator (like a Q-tip swab, etc.) and a very, very light amount of clear lacquer and lightly dab it onto the scratch and quickly wipe off the excess with a clean, lint free, cloth.
You can buy a can of clear aerosol lacquer that closely matches the type of finish on the fidge panels, (matte, satin, gloss).
The trick is to NOT spray directly onto the panels, but rather spray a small amount into the cap of the aerosol and using the swap, dip it into the liquid and, again, dab it lightly onto the scratch.
Another option is to purchase one of those automotive scratch repair kits that you see advertised on TV or in auto parts stores and follow the directions for fixing the scratch.
If you take your time and go lightly and carefully with the application, you can get a pretty decent repair that will make the scratch all but disappear. If it's also dented, then you've got another issue to deal with, but in any event, attempting a repair of the scratch will cost you hundreds of dollars less than buying a replacement door panel.
I hope you find this Very Helpful and best regards!
Oct 14, 2009 | KitchenAid KSSC36FMS Side by Side...
Scratched stainless steel
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
Mar 29, 2009 | Kenmore 99123 Electric Kitchen Range
Surface scratches in my black bathroom sinks
You might try a vehicle buffer on them. If that doesn't work you will probably have to use a porcelain touch up kit that can be bought at your local hardware store.
Mar 29, 2009 | Home
Miscellaneous Logo
14 people viewed this question
Top Miscellaneous Experts
extremebill
Level 1 Expert
tlaloc
Level 1 Expert
Cedric Murphy
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
