Question about Exercise & Fitness
Setting correct time fitbit 2 - Exercise & Fitness
2 Suggested Answers
emissionwiz
  • 78267 Answers
SOURCE: how do I set the correct time on my Fitbit Charge HR?
  • Log in to your fitbit.com dashboard and click the gear icon in the top right corner.
  • Click Settings.
  • Scroll to the bottom of the Personal Info page and modify your timezone.
  • After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
  • Posted on Jun 07, 2016
    How to reset time on fitbit sharge 2
    1. From the Fitbit app dashboard, tap or click the Account icon ( ).
    2. Tap or click Advanced Settings.
    3. Tap or click Time Zone.
    4. Turn off the Auto option and select the correct time zone.
    5. Sync your tracker
    Dec 23, 2017 | Exercise & Fitness
    How to set time on fitbit
    There are some specific things you can do depending ion what Fitbit you have, but without knowing that, here is some general advice. Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order. Check if your device has the correct time before moving on to the next step.
    1. Re-sync your Fitbit to your phone/computer
    2. Check your settings on your dashboard to make sure you have the correct time zone selected.
    3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
    3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
    4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
    5. Try resetting your Fitbit (specific instructions depend on which one you have).
    Oct 20, 2017 | Exercise & Fitness
    How do I reset the time on my Alta fitbit?
    Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
    Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
    Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
    Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
    After you see the logo you can unplug your tracker from the charging cable.
    Hopefully one of those things will get you on the correct time :)
    The time is wrong on my fitbit hr
    Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
    3. Make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit in your Bluetooth settings.
    Hope that does the trick!
    Oct 17, 2017 | Exercise & Fitness
    My fitbit has the wrong time on it.nhow do i amend the time
    Oct 07, 2017 | Exercise & Fitness
    How do I change the clock time on my fit bit surge
    1. Re-sync your Surge to your phone/computer
    4. Try removing the Surge in the Fitbit app (should be under device settings) and then reconnecting it.
    Hope that helps!
    Dec 27, 2016 | Fitbit Surge Large-Size Fitness Watch with...
    I can't find my instructions. how do I correct the time on my fitbit charge?
      1. Editing your timezone settings
        1. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard.
        2. Choose Settings > Personal Info and find the Time section.
        3. Choose your timezone and select your 12-hour or 24-hour display preference.
        More items...
        Help article: How do I update my Fitbit settings? - Fitbit Help
        https://help.fitbit.com/articles/en.../How-do-I-update-my-Fitbit-settings Fitbit
      Feedback
    1. The time is incorrect on my tracker's display - Fitbit Help
      https://help.fitbit.com/.../The-time-is-incorrect-on-my-tracker-s-disp...
      Fitbit
    Jan 03, 2016 | Fitbit Charge Wireless Activity Tracker...
    The time on my fitbit is incorrect. How do I correct. Currently it registers 9:43, but, I'm on Eastern Standard Time.
      1. Editing your timezone settings. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard. Choose Settings > Personal Info and find the Time section. Choose your timezone and select your 12-hour or 24-hour display preference.Mar 10, 2015
      Feedback
    Jan 03, 2016 | Exercise & Fitness
    Exercise & Fitness Logo
    91 people viewed this question
    Top Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
