Question about Cell Phones
My Bluetooth earphones won't connect with my iphone almost all the time- I like it, but it just won't connect even when I am so close to phone and it says "power is on" . Any help?
  • 21 Answers
SOURCE: After I dock Iphone 3G in JBL Stage II an error message opens
Check the iPhone's connector. There may be a pin problem that triggered the issue. iPod/iPhone connectors are known to have such problem.
You can also clean or use cotton bud to clear out any excess dirt in the connector. That may help.
Posted on Apr 25, 2010
  • 5 Answers
SOURCE: My iphone will not connect to other phones or
iPhone is known for not connecting well with other phone brands than - another iPhone. Now, problem connecting to a Mac - is a problem - it shouldn't be at all.
you weren't specific enough, have you managed to link to a bluetooth earphone? does the iPhone "jailbroken" (software modified in any way)? 1. I would try to connect to other Macs (if possible). if this will not work, 2. make sure you have the latest software update, and if that won't solve it, 3. back up your data, and perform a clean restore (done through iTunes) - these solutions assuming your phone is not Jailbroken or modified in any way.
Posted on Nov 15, 2010
wb91
  • 126 Answers
SOURCE: it cannot connect with mobile
Here is something to try on your iPhone. Hopefully it should fix your problem.
On the iphone, delete all the headsets you may have used from the UI of the iphone.
Turn off the headset.
Warm reset the iphone, press and hold the home and power keys on the iphone for 10s, the screen will go blank and the phone will reset.
While the iphone is rebooting, turn on the headset again and put it into pairing mode with the LED flashing red/white, red/white ...
Now when the iphone is ready, make it search for the headset.
When you see the "9xxPlantronics - Not Paired" entry on the iphone UI, then tap the screen where this message is displayed and the iphone will pair to the headset.
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 22, 2011
HDI Headsets
  • 537 Answers
SOURCE: explorer 240 keeps shutting down
It may be something having to do with an upgrade application that may have been done. If this was what happened then you may have to down grade back to original settings. If this is not the case I would do a hard reset with cell phone let your battery go dead, remove from phone. place it back in and recharge re do the pair and or subscribe.
Plantronics Explorer 240 User's Guide
Good luck from Headsets Direct!
Posted on Nov 11, 2011
SOURCE: IPHONE 4 WON'T RECOGNISE BELKIN F82498 TRANSMITTER
I am having the same problem, My iPhone 4S recognized the Belkin transmitter for over a year now it doesn't work. It does recognize other iPods and iPads, and works great. When it first stopped working I tried to uninstall the clear scan app and reinstall. Any suggestions?
Posted on Feb 05, 2013
How to connect the headset to my phone
Make sure they have the same bluetooth stack, or at least a compatible stack.
To understand what it means, before you look up what stacks your devices have, look here:
Bluetooth stack
Apr 17, 2015 | hittime J-MALL Universal HV-800 Wireless...
How do I connect my I phone 6 to my Joan earphones
If they are Bluetooth earphones, you simply pair them together. On the earphones, to put them in pairing mode, you usually press and hold on button for 5 seconds. Then put iphone into Bluetooth discovery mode. Settings>bluetooth. The device will show up, then click to pair. If it ask for a code, it is usually a default of 0000.
Dec 26, 2014 | Cell Phones
I did pair the turtle beach head set stealth 500 but when I turned off the power then turned it back on it won't pair with thePlaystation 4 system .?
what did you pair it with the first time? the ps4? if you pair it with one device and then want to pair it with different one, you need to either turn off the first one, which will make the headphone search for another signal or, there should be a bluetooth button on your earphones. this also makes it search for another bluetooth signal.
for example, i use my bose bluetooth speaker for my phone and my laptop. when it's paired with my laptop and i want to switch it to my phone, i have to turn on bluetooth on my phone, press the bluetooth button on my speaker and then it connects to my phone.
Nov 09, 2014 | Audio Players & Recorders
Iphone volume when disconnected from bluetooth
The iPhone detects when earphones are plugged in, and deals with volume differently as your speaker volume may be inappropriate for the use with earphones. Bluetooth is managed with the same volume level as earphones. Once it is disconnected manually adjust the volume with the volume buttons or check if your silencer button is not activated. Hope this helps!
Jun 01, 2012 | Apple iPhone 4S
I am unable to my i phone to another phone is that true that i phone only connect to other i phone via blue tooth?
Its true that you cannot connect your iPhone to other mobile phones. Ive even heard you cant connect the iphone to a macbook via bluetooth. You can connect your iPhone to headsets, handfrees, speakers etc via Bluetooth.
Jan 20, 2011 | Apple iPhone Smartphone
I don't know how to use the blue tooth on my altec wireless headphones
YOU SHOULD BE ABLE TO GO TO YOUR BLUETOOTH ON YOUR PHONE AND SEARCH FROM THERE . IT SHOULD FIND YOUR HEADPHONES.
Mar 12, 2010 | Altec Lansing EARPHONE BACK BEAT PLUSIPOD...
HTC Bluetooth Connectivity with JVC AVX800
can't connect my htc phone(3450) with bluetooth earphone
Sep 16, 2008 | JVC KW-AVX800 CD Player
Jabra SP5050
Not all models of Bluetooth earphones are compatable with every phone. Contact Apple support to find out if the model you have is compatible.
If the Apple tech says that the model earphone is compatible, then you should try another earphone to verify if the iPhone Bluetooth section is defective, or if the earphone you have is defective.
Jerry G.
Jun 05, 2008 | Jabra BT350 Bluetooth Headset Headset
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
