Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
My HP Pavilion computer unit will not turn on. Have tried unplugging, replugging; all the cords/plugs look good. Unit is quite old (at least 10 years). Monitor still seems to work. Is it dead?
  • 20 Answers
Could simply be your power supply. Please check that the power cord is connected to the computer and that the power supply switch (located in the back next to where the power cord plugs into the computer) is in the on position( I = on 0= off). IF the power cord is plugged into a working outlet and the power supply is on then it can only be one of two things. You have a bad power supply( easy fix that will only cost you about $50 or less) or your motherboard is bad. If you took this into a shop for repair they would pull out the power supply and replace it with a know working one. If that does not fix the problem then they would tell you your motherboard is bad. Power supplies are fairly easy to replace and, for your unit, very cheap, about $15 from newegg.
Posted on Jul 20, 2009
    Scholar:
  • 122 Answers
If you have no activity at all, no lights, no noise at all etc. it is probably the power supply. It can be replaced with some mechanical skill and attention to where the wires plug in, but the major problem is the age. Older computers have a different power supply then currently available. If you have data you need to retrieve the physical hard drive can be removed and placed in a relatively inexpensive USB housing and accessed from a new computer. If you want to try and get it repaired find an older, small repair shop and with luck they may have or be able to locate the correct replacement. Since it is 10 or more years I would not put much money into repairing it so check in advance about minimum rates etc. so you don’t end with a money pit. Good Luck
  • 51 Answers
What may have happened is that if you had your side panel off the cable from the power button to the motherboard may have come loose try re attaching it. if thats not the solution try replacing your power unit. they are fairly cheep on sites like www.tigerdirect.com. and easy to swap. heres a link on youtube on how to swap. http://www.youtube.com/watch?v=xvClS_M-09o&feature=PlayList&p=618916B5FEF87164&playnext=1&playnext_from=PL&index=51
PC - dies no power, but comes to life after a few days if left unplugged. Then it works and at somepoint dies again (no fans, power, etc) How do I fix?
My first thought would be that it is a power supply problem. But, before replacing the power supply, unplug the power cord from computer and wall plug, plug it in a gain making sure it goes in all the way.
If still flaky, its probably a power supply problem.
Hope it helps.
Jan 20, 2015 | HP Pavilion 725n PC Desktop
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The battery light on the tower stays on.
pull out the pwr cord and press the pwr button for one min and then release. this process is called as power drain. replug the pwr cord at the back of the computer and check. if its works then good or else replace the SMPS the power unit inside the computer. for sure it has gone bad. power unit is easily available in nearby retail outlets.
May 12, 2010 | HP Pavilion 520c PC Desktop
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
HP 1610 "scanner Failure" message
It MIGHT be that the unit is no good. The downside of ALL IN ONE products. BUT, unplug the power cord from the back of the all in one, then unplug the USB cable, then unplug power cord from wall. Wait 10 minutes and plug everything back in in reverse order and see if it works. If not it is bad.
Jan 18, 2010 | HP PSC 1610 All-In-One InkJet Printer
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
HP C6180 all in one
Have an HP C6180 that would not turn on, no power. Unplugged and replugged the unit in the back - no fix. Unplugged the unit at the wall socket, reconnected and I thought I heard a faint click in the power supply. Hit the on button and the C6180 powered up - no issues. Without knowing for sure, possibly the power supply has some type of surge arrest safety switch.
Aug 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
WARNING: PC ENTERING POWER SAVING MODE
sounds like a faulty power supply unit
Mar 24, 2008 | HP Pavilion a450n PC Desktop
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
2,870 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
