Question about Cameras
Message protect The machine when you switch it on, it gives a message - protect - and then it switches off?
  • kakima Dec 07, 2016
    Hi Jeanette van Rheede, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model camera?
Habubnik
  • 114 Answers
SOURCE: "Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Posted on Aug 29, 2005
SOURCE: Write Protected
I have this same Problem... urg It pissed me off!! I can't find any way to resolve it, and the company I bought the camera from is now closed!!!!!! SOMEONE help!?!?
Posted on Aug 09, 2007
  • 1040 Answers
SOURCE: camera gives following message when switched on
There could be a battery problem or software problem or mechanical problem...
first try with by inserting another battery. or update firmware of your gadget........... If problem persist then get it serviced
Posted on May 03, 2010
sonicboomele
  • 1557 Answers
SOURCE: Replaced the batteries & now a message reads
check your memory card a lot of people dont realize there is a little button on the side that if pushed up or down it locks the card so it cant be writen over .
Posted on Dec 02, 2010
  • 152 Answers
SOURCE: WHEN I SWITCH ON MY
Take out the SD card and slide the button on the side in the opposite direction it is in now. That should fix it.
Hope it helps
Steven Cumming
Please leave positive feedback :-)
Posted on Jun 05, 2011
Protection Message
Protection mode is a shutdown to protect the circuits on the amplifier. This will come on if the speaker wires are shorted or if their is a lot of DUST on the inside of your machine. On some machines, protection mode will come on if one of the speakers is open (breaks). What I would do is check the earphone jack on the tv. Put a headset in and see if that works. Last resort is purchase a can of air duster.
Jan 13, 2014 | LG HT356SD Region Code Free Home Theater...
Memory cards work, t2i gives Card Write Protected message. Took battery out, reset settings to original, tried tape over card's protect switch
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2013 | Canon EOS 550D Rebel T2i Digital Camera
I don't kn how to remove the write protect on my olympus 1070
Have you tried moving the little switch on your memory card? That would be the main reason for your camera giving you a write protect message. also, try doing a settings reset on your camera in case something in there is giving you that message. If neither of those work then you'll most likely have to get your camera service by an Olympus Authorized Service Center. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10001
212-673-8400
Jul 01, 2011 | Cameras
Unable to take photos on my vivicam 8225 because it gives message of card protected. howdo i get rid of this message
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 21, 2011 | Vivitar Cameras
When switched on camera gives message - memory card is write prot
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 27, 2009 | Nikon COOLPIX S52c Digital Camera
I get problem with card when i inserte it it gives message card
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 09, 2009 | Samsung S860 Digital Camera
When swithched on the camera getting message protected card and unable to shoot photos
Try to slide the little switch on the side of the card in the other direction. That switch is like a write protect for the card. Good Luck.
Nov 16, 2007 | Gateway DC-T50 Digital Camera
Waste ink near full error message
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 01, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Nov 29, 2006 | Nikon Coolpix 5200 Digital Camera
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
