Have 0630545 ventless gas heater. was working fine. with pounding nails outside pilot went out won't relight. tried cleaning it without taking anything apart, no help. can't find manual online
  • Heating & Co... Master
  • 3,253 Answers
I would say you have blocked the pilot needs to be cleaned out try sucking it out with a shop vac .
Posted on Dec 07, 2016
Why does my blue flame ventless propane heater go out for no reason?
Did the gas man use a manometer when the gas pressure was adjusted up? The three basic types are 1. round needle guage capable of measuring approximately 30" water column pressure, 2. U-tube manometer filled with a clear or red glycol, and 3. digital guage.
It sounds like the gas pressure is a few inches water column too high which could cause the pilot flame to actually lift off the thermocouple tip causing flame failure after the gas valve opens. More is not necessarily better when it comes to gas pressure. Normal propane manifold pressure is around 10.5" w.c. with maximum inlet pressure of 14" w.c. This pressure can be accurately measured with one of the above listed manometers by tapping into the manifold downstream of the gas valve or in the pressure tap on the downstream side of the gas valve. Most normal 100% redundant gas controls have an individual pilot adjusting screw in the valve itself for adjusting the pilot size and pressure independent of manifold pressure.
Nov 22, 2014 | World Heating & Cooling
Propane ventless wall heater pilot light is to big
You have the correct pressure equaliser on the propane bottle giving the correct pressure.
  1. The minimum gas supply pressure must be 1" water column (249 pa) above the manifold pressure printed on the appliance data plate
  2. The maximum gas supply pressure must not exceed 14" water column (3487 pa or 34.9 Millibars)
Feb 10, 2018 | Heating & Cooling
I have a ventless gas heater. the pilot lights
It just has a little dust in the pilot safety and that makes it think low oxygen levels are present. Ti correct that situation I flush the pilot safety device with rust buster, I relight the heater with pretty good success. I have a page which shows where to clean and has a nice demo which shows exactly how it works HERE
Feb 28, 2010 | Heating & Cooling
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace heater and can't get the pilot light to light. In the past, I've had problems keeping it lit, so I've kept pilot lit all year. The other day I successfully used...
You should the value there should be a pilot ajustment screw
some times it is hidden under another screw but should be close to where the pilot light line hooks to the gas value
Dec 12, 2009 | Desa International Unvented Gas Space...
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
