Question about Sewing Machines
I have an Artista 180. It is not recognizing the embroidery module. The pins that connect the unit are not bent. Is it the board?
  • 185 Answers
SOURCE: Problems with embroidery unit
The machine should always be off when you attach the embroidery unit. Attaching it without it being turned off can damage the computer system of the machineor embroidery unit. It needs to be tested by a repairman.
Posted on Feb 25, 2008
SOURCE: artista 180 driner
hi you need to get the right software for artista 180.I have just sold
my 180 and i still have the software on my computer. You need
the software called CPS 4.1...EMAIL me at lfr6@bigpond.com i might be able to get a copy off my computer for you
Lawrence
Posted on Apr 29, 2008
SewExpress
  • 41 Answers
SOURCE: USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Posted on Jun 27, 2010
RickE1
  • 202 Answers
SOURCE: Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
  • Service Pack 2 for BERNINA Embroidery Software V5 (V5.0W)
  • Aurora driver for 64-bit Windows® operating systems
  • Latest dongle driver
  • EConPC 3.1 & ADX 7.14
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
Posted on Jul 12, 2010
  • 166 Answers
SOURCE: cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Posted on Nov 24, 2011
Why doesn't it recognize that an embroidery hoop is attached?
Perhaps this will help:
My Embroidery Haven View topic Bernina 180
Bernina artista hoop not recognized
You can also try contacting the Support group at Bernina.com or your local Bernina dealer
Feb 24, 2016 | Bernina Artista 180
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
I have a Bernina Artista 180 with embroidery module. I put in the plug in the wrong direction once and now it will not connect the module to the sewing machine. Can this be fixed?
It is very likely that when you attempted to connect the embroidery unit with the plug out of alignment that you would have bent some of the pins on the male side of the plug. It is possible, though not advisable, to straighten the pins in this pug. However, if not done perfectly, this could cause further damage to both the male and female sides of the plug. I would recommend taking it in to a local BERNINA dealer and repair center to have that cable replaced just to be safe.
You can find a nearby dealer at: http://www.bernina.com/en-US/Where-to-Buy-US/Store-Locator
Sep 22, 2015 | Bernina Artista 180
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
The embroidery unit no longer registers on my artista 180 when I connect it. I borrowed a friends embroidery unit and it worked so i assume it not the 180 which is the problem. What should be my next move...
If you bought the embroidery unit with the machine, I would try to take it back to the place of purchase & ask for a sewing tech to check the machine & unit for you.
I recently had a similar issue with my machine-took it to a local bernina agent & within a week, it was back in my sewing room, at no cost to me. I hope this helps you, & yes I have a 180 with the embroidery unit like you mentioned
Jan 05, 2011 | Bernina Artista 180
Happy stitching,
Kim
Jun 23, 2010 | Bernina Artista 180
Bernina 180E Embroidery module not recognized
Anytime there is a communication issue between machine and module attach the module to a different machine and check it. Possibly at a dealership. This will tell you whether its the machine or module. If its the machine then the soldering points on the embroidery module plug to the A-print (on the side of the machine) circuitboard need to be checked. Then most likely replace the A-print circuitboard.
There are other tests that need to be done in the service program that will help pinpoint and troubleshoot issues with the embroidery unit. Such sensors or stepping motors, etc. Should be left to a tech.
Hope I helped.
Jan 25, 2009 | Bernina Artista 180
Feb 19, 2008 | Bernina Artista 180
Artista 180 driner
Lawrence
Feb 16, 2008 | Bernina Artista 180
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
