Question about GE Kitchen Ranges
I believe I have a bad control board in my GE Profile 36 Telescoping downdraft. Model number JVB96SASS. How do I confirmn that and how do I replace it?
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
SOURCE: 30 INCH TELESCOPING DOWNDRAFT VENTILATION UNIT
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Posted on May 13, 2009
  • 574 Answers
SOURCE: I need to replace a cracked glass top (GE Profile
If you dont see it around the door or inside the stove you'll have to raise the top and it should be there somewhere. The part number for the glass top I can get for you if I have the model number
Posted on Sep 08, 2009
aasc
  • 1606 Answers
SOURCE: GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Posted on Sep 26, 2009
I have a 36" GE Profile gas stove w/telescoping downdraft. (GEJVB98SH1SS), but I have no idea how to install filter (WB02X10940) ?
There is generally a release tab at one side of the housing (snorkel) that you turn to release one side of the filter
Jul 30, 2016 | GE Kitchen Ranges
Jxb37 won't lower
My unit always goes up. Sometimes it doesn't go down. Then, after some time it goes down. Could it be the capacitor is bad?
Mar 10, 2014 | GE Profile JVB67HWW 36" Telescopic...
I need the small control module for a GE downdraft telescopic vent, part no. 959-0138-003 (ACT, Inc.). GE page does not recognize the part number. Where can I get this part?
Does anybody know where I can get a copy of the schematic for the control PC board P/N 959-0138-003 by ACT, Inc. for the GE Downdraft Vent model no. JVB98SH1SS?
Thank you.
Oct 20, 2012 | GE Profile JVB67H Kitchen Hood
Ge JVB67 downdraft was stuck - didn't come up. Now, when plugged in, the motor "runs" constantly and vent will not rise.
you will have to disassemble the mechanical area to get to the moving parts and also clean and lubricate the telescoping parts with WD-40.
Mar 16, 2010 | GE Profile JVB67 36" Telescopic Downdraft...
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Ge downdraft vent
try removing the switch from the ribbon connector, and then jumping the two pins momentarily with a screwdriver blade or other metallic tool. It could be that the switch itself is bad. This is the same problem I'm having and I am currently looking for a replacement switch online.
Jan 23, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
GE Profile Telescoping Downdraft system gets stuck.
try to remove your cooktop and see if the vent unit is in your countertop too tightly. by removing the cooktop it will give the vent more space. if it works that way, then you might have to make more space for both to fit properly. i have seen this happen before and its probably what is causing it to bind and then drop suddenly. i hope you dont have a marble, slate or rock type countertop as they are very hard to trim just a little off to get everything to fit.
Jan 07, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
Sep 04, 2008 | GE Profile JVB67HWW 36" Telescopic...
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
