Question about Kitchen Ranges
Is there an air adjustment for surface burners>
This is a kenmore 790.753233310 gas range. the turbo burner is very high with yellow flame.
  • 131 Answers
SOURCE: burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Posted on Mar 10, 2008
SOURCE: low flame on burner on
This sounds to obvious but did you try and clean out the burners just dont use a wooden tooth pic use something that wont break off.
Posted on Sep 19, 2008
  • 3 Answers
SOURCE: the southbend 436d range gives a yellow flame at the burners
This model Southbend range is "built to order" for the gas type.
Orifice alignment is critical on this model especially on propane, so make sure that the orifices are pointing directly down the burner venturi tube.
Also, the air shutters for the open top burners will probably have to be wide open.
If you are in an area with an elevation higher than 2000 feet above sea level, you will have to run a smaller orifice.
Those are nice ranges. Good luck!
Posted on May 19, 2009
  • 1304 Answers
SOURCE: Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Posted on Oct 05, 2009
  • 8220 Answers
SOURCE: oven burner smokes
Right at the base of the burner is the air shutter and orifice. Tighten down the orifice with a good fitting wrench. then open the air shutter all the way for propane. Make sure the regulator is set for LP if this is LP and I am guessing it is. I happen to have a training video which shows how to: HERE
I have it on that page with them other interesting videos and I ain't no pc genous so you will have to find it on the page. sowwy. LOL
Posted on Feb 26, 2010
Tappan signature 2000 adjusting the flame from the burners they are burning yellow
yellow flames in gas burners indicates
1--insufficient gas pressure
2-- the position of the air shroud around the gas jet is wrong and needs to be moved forward or back to adjust the amount of air available for the air /gas mixture
correct mixture is a blue flame
Jan 09, 2016 | Tappan Kitchen Ranges
How do I adjust the side burner on my kenmore gas grill?
You should find an air mix adjustment for that burner. Try opening it a little, to allow more air. A yellow flame indicates too rich a mix.
The adjustment is probably behind the knob for that burner.
Aug 10, 2014 | Kenmore 4 Burner Gas Grill with Side...
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
HI, To adjust the size of the flame, turn the orfice clockwise to make it smaller. you can also try and adjust the air shuttle on the burner.
Are you trying to change from natural to LP?
Please let me know if I can assist you further.
May 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flame does not seem hot enough - too much yellow flame.
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Jan 05, 2009 | Kenmore 63942 Dryer
Burner flame height adjustment
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
