Question about Refrigerators
We have a Jenn Air refridgerator that we do not need. We want to move it to the garage. Unfortunatley there are tree steps in between. How can we move it?
    Master:
  • 252 Answers
Maybe you can ask a neighbor if they have a hand truck and can help you move it?
Best Value Folding Hand Cart 150 Lb Capacity
How to Move Refrigerator
or perhaps a local moving company can help you for a fee.
Posted on Dec 07, 2016
Freezer working, refridgerator not, what could it be?
freezer is where the cold comes from . then the fans move the cold to the fresh food area .. ck for ice build up in back of freezer and make sure the fan inside is working .. clean the coisl under neath . and ck fan . if iced coil in freezer . ck the heater and terminator .. if ok replace the defrost control .. hope this helped mm feed back pls .
Jul 10, 2011 | Jenn-Air Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Our 12 yr. old jenn air refridgerator freezer ice maker has not shut off twice and ran all over our kitchen floors. What can be done?
I HAVE THE SAME PROBLEM. AN APPLIANCE REPAIRMAN SAID IT WAS A MANUFATURER DEFECT. SUPPOSED TO BE A SIMPLE FIX. I HAVE NOT HAD THE TIME TO GET IT DONE.
Dec 27, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
How do I reset the change water filter light?
On my Fridge you press and hold the reset button for 3 seconds if that dont work has the filter been replaced?
Apr 04, 2009 | Jenn-Air JCD2389G Side by Side...
Locked freezer
Press and hold the lock button for at least 3 seconds
Feb 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
I plugged in my jenn air bottom freezer refridgerator and the freezer is getting cold but no the fridge
hi thanks for the question. it takes at least 24 hrs for a fridge to get cold. so depends how long its been on. if on for more than 24 hrs. check the fan motor in the freezer . thanks the appliance doc. please rate my answer. thanks.
Oct 08, 2008 | Jenn-Air Refrigerators
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
