Question about Samsung Microwave Ovens
I have samsung oven model CE103VD. No buttons working except stop button which on pressing displays code E22. What does it mean? Please help.
    Master:
  • 252 Answers
You'll have to call Samsung Customer Support.
Samsung Call Center
(1-800-726-7864).
Posted on Dec 07, 2016
  • schwaa44
    schwaa44 Dec 07, 2016
    https://www.manualslib.com/manual/674986...
  • Aw saeed
    Aw saeed Dec 08, 2016
    Thank you for giving contact number of service centre. Would appreciate if anyone knows error code E-22
What does se mean on Samsung over the range microwave model #smh9207st
The SE error code means a key has been depressed for more than 10 seconds. Press the "Clear" button, does it reset and work normally? If not, try completely cycling power to it. If that doesn't work you will probably need to replace the touch pad assembly.
Aug 02, 2016 | Samsung Microwave Ovens
Information about how to use samsung oven model no ce103vd .
You will have to contact Samsung for a user manual.
Aug 02, 2015 | Samsung Microwave Ovens
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Microwave beeps and with each beep a 6comes up on display, and the START under the numbers flashes, but I am unable to press any buttons to clear it. Also sometimes I can open the door and press the...
You didn't mention your brand or model number, so I can only give you a general response.
It sounds like a shorting membrane keypad.
On Samsung's, they will show the error code "SE".
For detailed do it yourself info and/or an estimate, please post a new FixYa help request and include the model, or contact me here with that info.
Jul 25, 2011 | Samsung MW6351G Microwave Oven
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
SMH7178STD Not working properly
E4 means your thermistor (temperature sensor) is shorted or caked with grease, making it look shorted.
Normally you can get Samsung parts here: http://www.samsungparts.com/search/search.asp
But that part does not show up on a search so you'll probably have to call them:
J & J International, Inc.
311 Route 46 W, Suite E
Fairfield, NJ 07004
Tel 800.627.4368
Fax 973.276.9078
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 21, 2008 | Samsung SMH7178STD Microwave Oven
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
155 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
