HI, I have a White Rodgers model 1F89-211 thermostat. All I did was move it to the opposite side of a wall into another room and now it runs backwards. I heats on cool and cools on heat. Help?
  • Heating & Co... Master
  • 3,001 Answers
Phillip...
The SECRET is to connect it exactly as it was (before).
The screws on the control are color coded
R,W, Y AND Green... TYPICALLY that MATCHES THE TERMINALS OF THE SAME COLOR inside you heater controller.
Yes ... Red, White... Yellow...
What you need to do is look at the picture you took... or the notes you took BEFORE disconnecting those wires...
ELSE...
Go to where the HEATER CONTROL BOARD IS...
Pull the front cover... Snap a picture for your memoirs...
and write a TRUTH TABLE
AT THE HEATER... TAKE NOTES...!!
RED SCREW = (for example red wire)
Yellow =
Green =
White =
BACK AT THE Thermostat Screws:
RED = (
SAME COLOR WIRE as at the HEATER)
Yellow = (SAME COLOR
WIRE AS THE HEATER)
Green = (
SAME COLOR WIRE AS THE HEATER)
White = (
You should be fine...
Carnac the Magnificent
Posted on Dec 07, 2016
I have a white-Rodgers 1F86-244 thermostat. When I turn the temp down it clicks on. But when left to come on its own it does not. I replaced batteries & reset it several times. Do I need a new...
Hi. This is Aaron Moratalla from White Rodgers. The clicking sound indicate the relays inside 1F86-244 are working. Say you want heat and your room temperature reading (left side of LCD) is 70F and your set Temperature (right side) is 75F. When you push the down arrow and set it from 75F to 69F or lower then you should hear the soft clicking sound. Same thing if from 69F you increase it to 71F or higher. If you don't have the clicking sound it means your thermostat could be broken. If that is the case then call our Tech Support at 800-284-2925. It's line is open M-F from 7AM to 1Am CST and Sat-Sun from 7AM to 4PM CST. Thank you for choosing White Rodgers!
Feb 01, 2013 | Home Security
The room temperature on my white-rodgers thermostat model 156-5299 keeps increasing
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. 156-5299 is a invalid model number To better assist you with this contact White - Rodger's technical department at 18002842925.
Sep 02, 2012 | White Rodgers White-Rodgers 1F85RF-275...
My thermostat is a wall mount White Rodgers. The thermostat keeps going completely clear with no reading every week. what is wrong?
Try replacing the battery if you haven't already done so. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab
Jan 10, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Where is the model number of the thermostat located? just moved into a condo with the White Rodgers thermostat and need instructions on use.
It's probably on a tag on the back of the unit, but you will probably have to remove it from the wall mounting to be able to read it. If it is the 1F85RF-275 model you can download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Dec 11, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I bought a house and its equipped with white rodgers thermostat controller for its furnace. only problem is i do not know how to control it and also even i can not find the model number of that
Remove the unit from the wall; the model number should be on a tag on the back. The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Nov 09, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have a problem with a White rodgers 1C20-101 thermostat. The lower heat setting for room temp goes up to 80 degrees when the thermostat is set at 70 degrees. Is this normal for this type of unit?
Oct 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have the thermostat set for 70 degrees on the white rodgers programmable thermostat. The heat runs until the room is 70 degrees, but then the heat stops and the room cools off and the heater doesn't kick...
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
Jan 03, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
