posted in wrong category, but you need to contact your network provider and they will give you the code after verifying who you are. (or in some cases use their website if you are registered). I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
After further research into the phone, I have discovered that it does not support any 3G network and as vodafone and O2 in Ireland are now 3G networks, neither the I9 or the I68+ will work on these networks. They only support 2G networks(GSM). Will work with Meteor Irl but this network is in the process of changing to 3G so these chinese phones will soon be useless in the Republic of Ireland.
Normally , one base can register 4 hanset in EEPROM setting. The model, Maybe you can try press the "page" key, then plug the power cord , after 5 to 6 second , release "page" key. Try to register handset again.
RECEIVED THE FOLLOWING INFO FROM A PANASONIC REP IN TORONTO PERTAINING TO SETTING UP A SECOND CAMERA:
"THE FIRST CAMERA MUST NOT BE AT ADDRESS XXXX.XXXX.XXXX.253 (EXAMPLE 192.168.1.253). DO ONE OF THE FOLLOWING BEFORE SETTING UP THE SECOND CAMERA:
1. CHANGE THE IP ADDRESS OF THE FIRST CAMERA THROUGH STATIC SETUP (EXAMPLE 192.168.1.252)
2. DISCONNECT THE FIRST CAMERA FROM THE NETWORK PRIOR TO SETTING UP THE SECOND CAMERA. (THE FIRST CAMERA WILL GRAB A NEW ADDRESS THROUGH DHCP THE NEXT TIME IT IS CONNECTED).
THE REASON FOR DOING ONE OF THE ABOVE IS THAT THE FIRST CAMERA IS PROBABLY STILL AT AN IP ADDRESS ENDING IN 253. A NEW OR FACTORY RESET CAMERA WILL WANT TO GRAB THE SAME ADDRESS AND CAUSE AN IP CONFLICT ON YOUR NETWORK.
