Question about Cuisinart Food Processors
Buttons light up but motor does not come on Cuisinart FP14-DC
I need replacement chopping blade. Help please
You should be able to do a search for your particular manufacturer and model food processor using one of the search engines. For example if you are looking for a Cuisinart model CH-4-DC chopper blade enter the search terms Cuisinart Model CH-4-DC chopper blade replacement in your search engine. Amazon is usually a pretty good place to start.
Mar 29, 2015 | Food Processors
I have a DC 8 (DLC 8) Cuisinart Food Processor, 15
Your Cuisinart should be warrantied for a little longer (25 minus 15 years) so call the factory to authorize a return or see if you can drop it off at a local retail outlet to save you shipping costs (CA law requires them to accept it for service)..
New ones are only warrantied for 3 years and they cost about $200 on up.
I think your best investment is to get it fixed.
Mar 28, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart MP14 Will Not Turn On
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Food Processors Logo
67 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
