Question about Sharp AQUOS 60" 1080P 120Hz LED Smart HDTV - LC-60LE660U
Sharp aquos LC-60LE660U image and backlights pup up then dissapear after a fraction of a second. I replaced the Tcon board already but didn't work. Can it be the power supply?
  • 927 Answers
SOURCE: Where do I buy Sharp
Good Day, coopsl;ine;
Try calling (630)-226-2699; SHARP, or go to NATIONAL PARTS CENTER: parts@sharpsec.com. Good luck, big IRISH.
Posted on Sep 09, 2008
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
  • 308 Answers
SOURCE: If my Sharp Aquos 37in LC-40C37U tv needs to be
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Posted on Apr 30, 2010
Testimonial: "Thank you. I will get another board."
SOURCE: sharp aquos model LC-32D40U screen goes black
The Sharp TV model LC32D40U / 41U "Black Screen problem" is a very well known issue. The inverter is losing ground contact which will prevent the back-light from staying on. The solution is to re-tighten six screws on the inverter board. You also would want to clean the copper contacts on then bottom of the inverter where the screws go through. Access to the inverter board will require some disassembly. Plan on taking at least three hours to repair. See the photo for the location of the screws. Use some "blue" locktight" on these six screws. There is actually a Sharp Technical Service Bulletin that describes these screws. Sharp wants you to replace these screws with a newer version. They cost at least $2.50 each! I think my method will work just as good using the "Locktight"_548.jpg_547.jpg
Posted on Jan 24, 2011
wadejohns229
  • 3 Answers
SOURCE: Sharp lc 32sh20u when power
WELL FOLKS I just FINALLY found what I have been searching for, I own a Sharp LC 32SH12U LCD TV that has begun to show problems with it's picture, Now it's sound is great no change..But it has gotten to the point that when i first turn it on all I get are three or four bright WHITE lines on the right side of the screen. They are a bout one third from the very corner of the screen.After it warms up for a while, MOST of the time it will just pop up and go to working just fine, that is what was giving it away to me that it HAD to be a something generally easy to fix, And in all of my searching I FINALLY found what I was looking for..Rite here on FixYA.com...There it was right thre in PLAIN ENGLISH..(( The T-CON BOARD )) Timing Control or LCD Controller..Board. on teh LCD panel Assembly, It transfers the image signal of the TTL and LVDS signal to specific TFT but What you all really NEED TO KNOW is JUST what is going on with your TV set when the T-CON Board is going bad, And I am about to tell you....So her ya go.. If you TV has any of these symptoms Well then I can pretty much say that your T-CON Board is bad or going bad...OK..If you have A Scrambled Picture,LINES,multiple Pictures Color smears, blotches, Rolling Pictures after warm up, Blown Surface mounted Fuse No Picture, Very Dark Screen almost like there is no backlight....Folks if your SHARP LCD TV is doing ANY of thsi then you just may need to replace your T-CON BOARD!!!! Hey it beats buying a new TV RIGHT!!!! GOOD LUCK FOLKS!!!!! I have already bought my replacement T-CON Board, as soon as I get it and install it I will let everyone know how it went!! PLEASE CROSS YOUR FINGER"S AND PRAY THAT THIS WORKS FOR US!!!! Thanks Wade in Eastman Georgia...
Posted on Mar 30, 2012
70 sharp aquos tv. light blinks five times, two slow
You already have done all the necessary tests. Your LCD Panels Drive board which comes after the T-Con on other side is faulty. You have to replace the LCD Panel itself to fix the problem. The cost of the panel may be more than the price of a new TV Screen.
Feb 02, 2018 | Sharp Televison & Video
SHARP 70 AQUOS Q+ LED SMART TV Left side of screen image is distorted.
The Tcon board or the LCD panel is faulty. Can confirm by replacing the tcon board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Sharp Televison & Video
How can i fix green lines in my screen
The tcon board or the LCD panel is faulty. Can confirm by replacing the Tcon board.
May 22, 2016 | Sharp AQUOS LC-45D40U 45 in. LCD...
Have a Sharp aquos that has a black ghosting all over the screen and menus. The screen seems to jump as well. So it is no individual source. The model # is a Sharp LC-60EQ10U
The TCON Board or the LCD panel is Faulty. Can confirm by replacing the TCON board.
Apr 19, 2016 | Sharp Televison & Video
How to fix my sharp aquos LC42D69U lcd tc
Use coldspray to find the bad component abad soldering or a few bad capacitors in the (mains) powersupply . knock and bend the electric print some little the beginning is the powersupply
SHARP LC 32D59U LC 42D69U Service Manual free download schematics eeprom...
Sep 24, 2015 | Sharp Aquos Televison & Video
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Horizontal Lines on TV
lcd screen or tcon board defective try to replace t con board first .ic chip over heated thats why it runs for few minutes then give you lines or bad image
Nov 26, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TURN TV ON JUST PLAIN SCREEN (NO IMAGE), THEN HEAR A CLICK & TV TURNS ITSELF OFF- THEN ON AGAIN... CHANGED BATTERIES IN REMOTE & TRIED TO TURN TV ON DIRECTLY FROM TOP... NOTHING WORK. THIS IS A...
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a lc-d45u sharp lcd that i get sound but no picture.
Ur LCD backlight inverter board is dead.Replaced this board will get picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD backlight inverter board,it a long board shape.
Mar 02, 2010 | Sharp Aquos LC-19D45U 19 in. LCD TV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp AQUOS 60" 1080P 120Hz LED Smart HDTV - LC-60LE660U Logo
220 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
