Question about Panasonic KX DT343-B Digital phone - Black
KX-DT343-the hand set is not able to make outside calls. It has a restriction so I would like to un-restricted this phone so it can make outside calls
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
cnavarro
  • 2460 Answers
SOURCE: How do I program my panasonic KX-DT343 handset to
You do that by programming the ICD groups on the phone system it's attached to.
It requires system programming access and probably a knowledge of ICD group 601.
Carl
Posted on Oct 06, 2010
  • 90 Answers
SOURCE: Hi i have a panasonic
dial *7105 followed by the extention number you want to forwrd to follwed by #
Posted on Nov 13, 2010
cnavarro
  • 2460 Answers
SOURCE: I am using Panasonic KX-T7730
There are specific instructions that the system manager can use to unlock a locked phone. Clearly, you might want to hear it on a public forum, but that's not going to happen. RTFM.
Carl
Posted on Nov 25, 2010
cnavarro
  • 2460 Answers
SOURCE: need to change hold music
It depends on where the music source is coming from. A Panasonic TDx system has a port for external music located on the system cabinet. If it's enabled in programming, that's what you hear. If not, you get an internal "tune".
If the music is exterhal, all you have to do is find the box that is playing the music and change the recordings. That's a whole other topic :-)
Carl
Posted on Feb 19, 2011
How do I transfer a call so that it goes directly to voicemail without the phone ringing? I have the Panasonic KX-DT343
Can you not download the KX-DT343 owners manual as a PDF and maybe you might find what you are looking for there not sure.
Feb 20, 2015 | Panasonic KX DT343-B Digital phone - Black
How to get speaker phone to work on Panansonic KX-DT343
Download the Panasonic KX-DT343 users manual and a pdf and there should be what you are looking for if not then there must be something funny going on with the menu system but why not have a look in the settings to see if the intercom setup is there but I think you will find out what you want from the KX-DT343.pdf file.
Dec 17, 2014 | Panasonic KX DT343-B Digital phone - Black
On my KX-T7453 how do I transfer a call to an outside line?
What you said. It has to be allowed in programming, called Call Transfer To outside line. It's done by class of service and programming.
Carl
Sep 13, 2012 | Panasonic KX-T7453 Corded Phone
I have a kx-dt343, when I'm on the phone, how do i turn off the ringer?
The Panasonic system has call waiting features that you can set or clear by dialing a code. From your phone, on the intercom, dial *7310 for Intercom call waiting and *7320 for Outside line call waiting and it turns the feature off. (11 and 21 turn it back on).
Carl
May 11, 2012 | Panasonic KXDT343 Phone
Hi, Can you help me my problem. I Need programming manual for KX-ta308. Specially for the restriction of outgoing calls on local extensions. Already downloaded a manual but cannot find outgoing...
Under alphabetic FEATURES, look at TRS (Toll Restriction) and COS (Class Of Service). It explains the concept of call restriction and how to program it.
We have a different 308 in the US, one that was built on a 624 platform, so a 624 features set will work, it just has a smaller number of lines :-)
Carl
Jan 31, 2011 | Panasonic KX-TA308 Phone
Dear Sir, I am using KX-TEM824 PABX system and KX-T7730 master phone.I have installed and configured all extension no by installing CD.But i want to block my staff to call in mobile number for eg. number...
That doesn't explain so well in a free forum. Try the features manual under TRS (toll restriction). COS (Class of Service) and Verified Toll calling. With restrictions, you set up a numbering plan that will bar mobile calls, then either verify and override, or alow only certain phones the ability to dial outside calls to those numbers. If you absolutely have to allow access to certain mobiles, you can add them to the Speed Dial tables where the call can be allowed by the fact it's in a speed call table.
It will take you 30-60 minutes to read and set up the programming.
Carl
Dec 23, 2010 | Panasonic KX-T7730 Corded Phone
How to block "0" for international calling and mobile calling in our office phone panasonic model no kx-t7730x
As was pointed out to me, you could take a screwdriver and pry the 0 key off the tone pads :-)
Panasonic systems restrict calls by tables called Toll Restriction (TRS). It's a complete section in the installation and programming manual. It involves setting tables, usually in the 302-306 area, then picking a class of service for the phone that acts on the numbers dialed.
In the simplest systems, the TA series, you have 20 restrictions per class 2-5 and one 80 entry exception table. It's a little tricky to set up in that a COS-2 extension has all the restrictions in COS-2 tables, but a COS-5 extension has all the restrictions in COS-2,3,4, and 5 :-)
Your Pana installer can do this fairly quickly, but if you plan on doing it yourself, please read the TRS examples carefully.
Carl
Aug 20, 2010 | Panasonic KX-T7730 Corded Phone
Restrict cel calls
This is a phone system feature, not a phone feature. Your phone can be used on different Panasonic phone systems so you will need to find out which system you have and get the manual for the system, not a phone.
Jan 13, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX DT343-B Digital phone - Black Logo
131 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
