Question about Home
I need help setting my centimos wall clock - Home
2 Suggested Answers
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
How do i change time
look on the back of the clock U will see how
Mar 29, 2015 | PT Present Time Wok Time Wall Clock, Metal...
John
Apr 21, 2010 | Watches
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Seth Thomas wall clock wont set to time.
either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
Home Logo
64 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
