Question about Watches
How to put strap onconstantin weisz watch 220 400
How to remove stainless steel wrist band on a marc
You should find a couple of pins buried away at the watch side of the strap. These are spring loaded and hold the strap in place using tension.
Simply put the watch face down on something soft, the clips should be visible at the corners of the strap and take some needle nose pliers or small flat screwdriver and push inward from one of the outer edges. This will squash the spring and enable you to remove the strap.
Oct 15, 2014 | Watches
How to repair my broken wrist band
The local SEARS store has a watch-repair department.
May 19, 2014 | Sportline Solo 910M Heart Rate Watch
Need a replacement strap
You can have a new strap put on at your local Wal-Mart.
Apr 22, 2012 | Nike Lance 4 Wrist Watch
Watch dial says 'WITTNAUER" at the top of the face; and"qwr" at the bottom.inside case has "R10449" and "swiss 9801" .i am trying to find a replacement wrist band. (generic pins and straps will not work,)...
Go to "" which is the Boluva site but they deal in this make. Put "straps" into their search box and a list of straps appears.
Alternatively, go to "". This company sells replicas, so presumably will be able to offer you a replacement strap.
Jan 01, 2010 | Watches
Diesel DZ1047 watch - need to replace strap
use a pocket knife and put the blade in the grove in between the strap and the steel of the case and pull towards the leather of the strap the pins are sping loaded and work simular to a miniature shower rods very simple so dont get nerves bout it if all else fails you can even just destroy them geting them out and get new pins and straps at wallmart for like 5 bucks
May 20, 2009 | Diesel DZ1090 Watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Oakley band/strap
I called Oakley customer service and they said mail in watch and they will put on a replacement band for 45 bucks
Oct 28, 2007 | Oakley Detonator OAK0530 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
