S/n 010654419 model GWN20T Natural gas Thermocouple part price
  • Heating & Co... Master
  • 3,150 Answers
You can pay any thing from $5 to $20 look for a Honeywell universal thermocouple . it also depends on where you go to buy it .
Posted on Dec 07, 2016
I have a Heat Dragon Reedy Heat 50 RLP50. It won't stay ignited when I let go of the knob after 30 sec or longer.
will need to check and test thermocouple --valve unit --and that your hooked up correctly propane [lp] to a propane unit or natural gas to a natural gas valve unit --also check flame is contacting the thermocouple
Dec 20, 2016 | Heating & Cooling
My whirlpool 50 gal natural gas water heater wont stay lit?
Are you sure the pilot is heating up the thermocouple? Make sure the flame is close enough to the thermocouple. Also make sure the thermocouple is seated properly in control valve. Try unscrewing and resetting it back into place.
Feb 10, 2013 | Whirlpool Water Heaters
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Charmglow natural gas fireplace, CQN300TQ, need a manual
looking where to buy a thermocouple for natural gas fireplace cgn 300tq
Nov 01, 2011 | Napoleon 36" Zero Clearance Top/Rear Vent...
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
I replaced my thermal couple and now too much gas at the pilot, what can I do...Art
Art - Just replacing the Thermocouple would not,/should not increase the length of the pilot flame significantly. Perhaps, it had been low for so long (prior to replacing the Thermocouple) it just seems unusually high (long). You didn't mention whether you're using Natural Gas or Propane Gas. But, the length of a Natural Gas Pilot Flame is normally 2" to 3" long. A Propane gas pilot flame is normally 3/4" to 1 1/2" long. If your heaters pilot flame is falling within these parameters for the specific gas type, you're fine.
Hope this helped you.
Apr 12, 2011 | Heating & Cooling
Pilot light will not stay lit on a empire gas heater model uh 1050 fsp natural gas
clean pilot light or replace thermocouple check thermocouple is tight at the nut end
Aug 08, 2010 | Heating & Cooling
Where would I find install instructions for a thermopile (lennox 11450097) to go into a gas earth stove model TG300DV
Hi and welcome to FixYa. I am Kelly
You do not even have to turn off the gas to the stove to change the thermocouple.
It is a matter of unthreading the fitting from the gas valve and routing the new thermocuple in the same matter as the old one. There usually are 2 -3 mounting screws for the thermocouple head. Remove the screws and install the new thermocuple head in the same place as the old one.
Before you screw the new thermocouple into the gas valve make sure the mating area inside the gas valve is clean then thread the thermocouple fitting into the gas valve.
Sometimes the igniter is also mounted on the same bracket as the thermocouple just be careful not to damage it if yours is installed in the same manner.
It should not take more than 20 minutes......
That is it.... simple as that.
Thanks for using FixYa
Feb 18, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
The pilot will not stay lit on my GWN20T. Have tried cleaning with compressed air. Would this be the thermocouple? If so can I replace with a universal unit? Lowes has a Honeywell 24' for a 30millivolt....
if the pilot stays lit while you hold down the nob and goes out when you let up on it then you need to replace the thermocoulpe and yes thye honeywell will work.
Nov 27, 2009 | Desa International GWN20T Heater
I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Dec 08, 2008 | Dayton 511 Utility Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
