Paper jam even tho I do not see any paper - Office Equipment & Supplies
  • 1043 Answers
SOURCE: my dell v105 paper jam light keeps flashing even tho there is no
There might be either a small piece of paper or dust covering the sensor. Take out all of the paper from the printer. Using a can of compressed air blow out the entire paper path. Try the printer again. If it still doesn't work then you may have to get the printer serviced.
Posted on Sep 12, 2009
sys_admin
  • 829 Answers
SOURCE: Paper Jam
Have you checked for paper jammed in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
Posted on Jan 13, 2010
drifterK
  • 4924 Answers
SOURCE: it prints the page then tells me there is a paper
it is a sensor malfunction ...and it the actual sensor remain blocked receiving the presence of the paper in the rollers area..even if the paper is passing by right ..it do not detect that ..and it remains in detecting the paper presence mode...or something like that ...
to fix it ..you should look for a way to disable this function (paper gem detection ) ..and use it ahead like this ...cause this is not something vital ..but it is annoying to stop you from working if it s not running proper..
so ...ask for a repair man in the area to disable that sensor ..or the function from the control panel...if it can ..
Posted on Mar 30, 2010
SOURCE: Receiving paper jam error even
You need to clean Transport sensor, use Compressed Air aerosol
Posted on Sep 28, 2011
matt800
  • 241 Answers
SOURCE: my printer says there is a paper jam problem even tho I've checked and everything is clear
It is likely that there is either some small piece of paper/other debris covering an essential sensor or that the sensor itself has stopped working.
First of all please inspect the printer carefully at every possible way in/out and ensure there is nothing jammed. Next turn the printer upside-down and shake gently from side to side and hopefully a hairband, paperclip or biscuit will fall out (all of which have happened to me).
If this fails to help I would recommend getting a A4 sized piece of firm card and push it through the printer like it was paper being fed. if any debris has been caught in rollers this should force it out.
If the issue remains I would contact your local Epson service center or retailer (if still in warranty).
Posted on Sep 08, 2012
Hi, my printer got jammed, and even tho there is no paper in it, it is showing a printer error. Any ideas?
A tiny scrap of paper in the "paper path" may send out this signal.
Open up your printer and look for it very carefully. It might be hidden from view.
To be safe, please do this with the power off, keeping hair, jewelry, etc. out of the way.
Sep 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jams and message comes up that the paper tray is empty even tho there is paper in it why is this happening ?
You might try checking to make sure there that the paper is set in the tray correctly. Here are some other things to check:
http://cincinnatiprinterrepair.com/paper-jams
Aug 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Paper Jam
Jan 13, 2010 | Brother MFC-7820N Printer
My dell v105 paper jam light keeps flashing even tho there is no paper jam. Have turned off and on again several times. Printer has just frozen and paper feed button does not do anythin.. HelP!!!
Sep 12, 2009 | Office Equipment & Supplies
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Not feeding from the A4 tray
Make sure your paper guides are set correctly in the A4 tray. Also make sure the tray is lifting correctly. Nine times out of ten its the tray guide set up.
When the tray lifts up and engages the rollers, if the tray isnt set up correctly the paper will wall back and the rollers will not be able to pick the paper up. Then the machine will call even tho there is no paper jammed.
Aug 17, 2009 | Toshiba e-Studio 232 Black and White...
Menu says paper jam and there is no paper jam
Open every single cover on the printer and when you close the covers close them HARD. Don't break it tho :)
May 28, 2009 | HP LaserJet 2840 Printer
22 people viewed this question
k24674
jasbo
jasbo
