Question about Tablets & eReaders
I replaced my router on my p.c tried to get wifi on kindle it showed that I was getting a connection but, I pressed a wrong digit on kindle now it will not allow me into my kindle what shall I do ?
    Master:
  • 252 Answers
Can you power off the kindle/reboot it, and restart it, then try these steps? (on the Amazon website?) otherwise, you'll have to contact customer support.
Connect to Wi Fi
Posted on Dec 07, 2016
I am having a problem with connecting my Kindle Fire to the Wi-Fi. When I try to sign in, it keeps telling me authentication problem. I can't get past this answer. Please help me.
WiFi pass word incorrect or there is an issue with the WiFi router. Check password...make sure exactly the same including capitalization. Try resetting WiFi router.
Oct 08, 2016 | Amazon Kindle Fire HD
I'm having trouble connecting my new Kindle to my wi-fi
trouble connecting my new Kindle to my wi-fi Mary, Check the attached links,instruction and guides to get kindle connected, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Can Connect Kindle 5th Generation to Wi Fi
Fix Kindle HD WIFI problem EASY
kindle won connect with wi fi
12 major Kindle Fire problems and how to fix them
Aug 03, 2016 | Amazon Kindle Paperwhite
My 4 year Kindle won't stay connected to wifi.
Probably location from Wifi router. I know some of the areas of my older home don't receive a good signal. Check your wifi bars and see if this is a problem due to only one green bar showing as a connection. Rich
Jan 18, 2015 | Amazon Kindle Fire HD
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Dec 27, 2014 | Amazon Kindle Wireless Reading Device
Kindle say authentication problem when trying to connect to wifi
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Mar 01, 2014 | Amazon Kindle Fire HD
Trying to connect kindle fire to wifi TheGriswalds has come up but do not have password help
Ask someone for the password, or if this is your router then you may need to factory reset the router and setup a new password
Dec 08, 2013 | Amazon Kindle Fire HD
Kindle 3 wi-fi - no response when switched on - battery has been charged and grren light comes on but screen graphic remains. I've tried holding switch on for 15+ seconds.
If the 15 second reset does not work, I would suggest contacting amazon. They can connect to your device and see if there is something wrong with your actual kindle. If there is something wrong they are usually pretty good about replacing broken kindled :)
Feb 10, 2011 | Amazon Kindle 3 WiFi
My Kindle (version 3) suddenly won't connect to my wireless network. I've re-entered our wireless passcode, but still doesn't work.
On a wifi connection when you see problems the cause will either be the device or the wifi router.
If you can try the kindle out on a different network this will tell you if it is the kindle or the network. If it connects then it not the kindle. It could be a setting or the router.
If it is a setting the two biggies are going to be something wrong with the security passcode or it isn't getting through the gateway out onto the internet. For settings you need to check things like using wep when it should be wpa or the wep key is 64bit when it needs to be 128 or in the wrong key location and so on.
When it can't get through the gateway that usually means your dhcp is wrong or you are using fixed ip. You can just set these numbers manually in the kindle.
The other usual suspect is that the router itself is beginning to fail. This usually shows up first as difficulty to connect and dropped connections or increasing errors. It will eventually fail. This is common and typical of all home grade wifi routers. They are good for about 18 months or so. If this is the case you might notice slow downs or dropped connections on other wifi devices. These units are not repairable so you just need to replace it.
Out of all the possibilities I would say your first choice would be the security settings and next would be the the router. Those are the two most common problems.
Feb 01, 2011 | Amazon Kindle Wireless Reading Device
Can not get kindle to connect to wireless or whisper. so at the moment it still shows that the kindle is not regestered but has been register online
You may need to enter your wep key.
wep key is a wireless key code found in your pcs router,Go to the routers home page and look under wireless settings.Somewhere on the kindles configuration you need to enter this code.
Jan 07, 2010 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
