Question about Coleman York Luxaire Furnace Control Board 02535304000 025-35304-000
I HAVE A LUXAIRE MODEL PCUHLD12N100A BLOWING COLD
I have a luxaire gas furnace and the gas valve keeps opening and closing. no codes when valve not connected, the voltage stays 24 volts. connected it drops out constantly
hmmm it seems like the luxaire furnace isnt able to tell if the valve is open or closed by electronic means try replacing the part and see if it helps
Dec 05, 2016 | Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Where can I find a wiring diagram for a luxaire furnace model number SSL110MS
Google your model number there seems to be a few out there.
Oct 09, 2014 | Heating & Cooling
Luxaire by York Furnace,Model# G8T10012UHB11A,8 Red LED Flashes = Ignition lockout due to recycles,Has flame for a few seconds then goes off; does it around three times,Fan is working; blowing cold air
It sounds like you have a dirty or bad Flame Sensor. They sometimes get a white coating on them. It's not detecting a flame so it shuts off. Sometimes you can clean them and they will work.
Nov 06, 2012 | Coleman Heating & Cooling
Luxaire air conditioner not blowing cold air
make sure the outdoor coil is clean and is running. if it is running you may have a small refrigerant leak and be low on charge
Aug 25, 2012 | Heating & Cooling
I have an older Luxaire furnace: Model # GSU137FF Serial # NAJTE Input 137000BTU out 110000Btu Natural GAS. What is age of unit, are parts available, whats is its efficiency rating. Should I fix or...
Your effeciency rating is 80%. Divide your output capacity 110,000 by your input capacity 137,000 and that will give you your effeciency.
The manufacture date is usually in the serial number.
You need to go to Luxaire.com and they can answer that question for you.
As far as parts there be parts available.
Fix or replace, if you are happy with the equipment and not really having a lot of problems, you may want to keep it. The newer equipment is more efficient, so if you think your gas bill is to high or you want to save some money on your gas bill, you may want to replace it.
Apr 09, 2010 | Heating & Cooling
What ton is my old Luxaire AC unit? it is model EESQ36
Sure but you need ot have an AC man to replace it and vac down the system plust change the dryer/reciever.
Jun 12, 2009 | Weather King 10AJA3601AH Air Conditioner
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Coleman York Luxaire Furnace Control Board 02535304000 025-35304-000 Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
