Question about Sewing Machines
Machine reverse running - Sewing Machines
    Top Expert:
  • Sewing Machines Master
  • 8,302 Answers
Have you followed your user guide instructions re making needed setting adjustments back to a sewing mode? Have you checked the guide for instructions on 'resetting to factory default' so that you can reprogramme?
If the above doesn't help, have you tried a 'shock reboot'? Start by turning on machine on and let it sit for a few minutes then without turning it off, pull the power plug from the electrical outlet. Wait five minutes then reconnect and turn on your machine - it should have defaulted back to factory settings. You'll lose your saved stitches but your machine should function properly again.
If that doesn't get your machine sewing forward, something the wee man did snapped something inside the machine (usually a gear and the things are easier to 'snap' than people realise) and it's time for a trip to the repair tech.
Be sure the tech has experience working on the Memory Craft series - great machines but the 4000 is a 'retired' computerised machine and unless you choose a 'factory trained - authorised' may not be qualified to work on vintage (sewer speak for 'retired' models) computerised machines.....
Sewing Machine Stuck in Reverse
Posted on Dec 07, 2016
I have a White model 3900N. Why does it only sew in reverse?
Hello Jan, I have run into this problem many times. The reason your machine only sews in reverse is caused by old sticky oil at the feed dog pivots. Oil your machine with only high quality sewing machine oil. Pay close attention to the two pivots under your machine where the feed dogs attach to cross journals. Oil them several times and work the reversing lever until the feed dogs move freely and easily. It will sew in reverse if you oil the pivots. Good luck.
May 02, 2015 | Sewing Machines
What my sew d Lite Works on reverse
Your reverse mechanism may be frozen. You need to place a couple drops of sewing machine oil into the mechanism. Remove the bobbin case, thread, and needle then permit the machine to run freely. While the machine is running, move the reverse mechanism up and down until it is free.
Mar 24, 2015 | Sewing Machines
How to fix sewing reverse
try to pull the fabric as you hold the reverse lever.....pull away from front towards yourself. the dogs pull the fabric in the opposite direction. make sure your stitch length is narrow or "1" ...reverse only works with a straight stitch foot not a zigzag. Sometimes a machine needs a little help getting the reverse mechanism going......
Feb 12, 2015 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
Creations 3 is sewing in reverse reverse button not lit
All serging machines run in reverse, the hand wheel turns reverse compared to regular straight stitch machines which run counter clock wise. I need more information, My email is rtarkington2@cfl.rr.com.
Jan 24, 2014 | White Sewing Speedylock 1600 Mechanical...
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
I have my Mother's Brother XL3750, no book or accessories. It will sew in reverse only. I don't even know where the reverse button is. The only thing that I have tried is the big lever front...
you can download a manual for your machine from the Brother website,
link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000452/bm2736xl26i35i375ug04enes.pdf
Reverse is the big lever in front but it should be sprung so you need to hold it down to reverse; if your machine is only sewing backwards, this lever might be stuck or locked into position. Check out page 25 and 26 in the manual for specific info.
Sep 10, 2011 | Brother XL3750 Mechanical Sewing Machine
Juki MO-2516N motor runs in reverse
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
Feb 01, 2009 | Juki MO-655 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
