How can i reset my dellvenue 5830 pro to factory settings. I forgot my system password
  • 73 Answers
SOURCE: forgot password have new laptop
Not really unless you enable your WEP settings then you will have a more secure line.....making a new passkey is required though...anyone who would like to connect to your router needs to enter this key makin it more secure and controlled...
In order for you to do this you need to reset your router to the default settings ....
Firstyou have to look for a small button at the back of the router, this isthe reset button...while the router is plugged press this button forlet say ten seconds then....follow the instructions on the linkbelow-----go to page sixteen(16)
Good Luck!!!! If you need more help, I could be of further assistance. If this helps or solves the problem, please rate it. Thanks, JCE
Posted on Apr 14, 2009
SOURCE: reset factory password on t61 lenovo
Pulling the bios battery does not work on the Lenovos - youll be wasting your time. Where did you get that information Jadestar - Ill bet you can't name one person for whom your solution works on these laptops!!???
Posted on May 21, 2009
SOURCE: how to reset VSX 8000 to factory default - Forgot the password
section 8, page 4
System -> Diagnostics -> Reset system
you will need serial number for this
good luck.
Posted on Jun 04, 2009
  • 40 Answers
SOURCE: mini iphone ka08 reset
Try restore factory settings: dial *#987*99#
There is a selection in settings as well to restore factory settings, the default password is likely to be one of the following:
1122, 3344, 1234, 5678 or even 0000
Posted on Dec 31, 2009
  • 523 Answers
SOURCE: Forgot custom password, have reset router and also
Hi Friend,
You have do a reset for your router
Step 1:Take a pen or a paper clip and insert it into the reset hole and hold it till the lights are getting flashing
Step 2:Once its flashing with out taking the hand from the reset unplug the power cable of the router and put it back after 10 to 20 secs
Step3: Then follow the below link to configure the Belkin router
If you have any Clarification please contact us any time
Posted on Apr 02, 2010
I forgot the password to my android 9.7 how do I rest it?
Factory Data Reset- Factory Data Reset can be accessed through your settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset tablet and Erase everything.
    2.Backup and reset on the left hand column
    3.Factory data reset on right hand side
    4.Erase SD card (optional)
    5.Reset tablet and erase everything
What do do if forgot my password to unlock to my tablet
Dec 20, 2015 | Mach Speed Trio Stealth Pro Trio Stealth...
I forgot the password. How do I reset system?
Usually there is a small reset button at the back of the router, which you need to access with a pin or a ball-point pen. A short press will restart the router, but if you hold it down for a longer period of time (usually around 30 seconds should suffice) this will factory-reset your router so that you can set it up from scratch.
Sep 17, 2014 | Computers & Internet
Forgot password on Trio 4.3" Internet tablet
If this tablet is linked to a gmail account, then enter five incorrect passwords and you should get a Forgot Password button. Follow the prompts to reset it.
Alternately you can factory reset.
  • Power off tablet
  • Tab power button then press and hold power + vol down
  • You should get a menu. Choose the factory reset option
Jan 03, 2013 | Mach Speed Trio Droid 2GB Internet Tablet...
How to retreive Wi-Fi WPA2 password which I forgot?
Hi there.
If you forgot your wifi password, all you need to do is reset your modem. Doing this will restore your modem to it's factory settings.
Find the reset hole, could be on the side, front or back of the modem. Unfold a paper clip and push the reset hole with the paper clip. Hold it down for about 10 seconds or until it turns off.
When you turn the modem on, it is already back to factory settings and it will no longer ask for a password.
Let me know what happens.
Thank you!
Sep 16, 2011 | Computers & Internet
Forgot password
I understand that you forgot your password to your router, there is only one solution to that, all you have to do is just simply Reset it to factory settings.
Now, how to Factory Reset it?
Just find the small pin hole of your router that says Reset There. Poke it for at least 10 seconds, after doing that your router will be reset to the factory settings.
Jun 17, 2011 | Computers & Internet
Forgot asus RT-G32 router login password. How to change the password?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Dec 19, 2010 | ASUS RTG32 Router
I have forgot the password for my tenda router i.p address how do i get it?
You can only reset the router to its factory default setting by pressing the reset on the back. Instructions for resetting the router & the factory user name / password are located in the manual.
Nov 13, 2010 | Computers & Internet
Asking for admin password
The experience that I forgot Windows password happened to me a few weeks ago. And my classmate recommends me to take use of Windows Password Recovery 6.0, which is very smart and just take me a short time to reset a new password. It is great and you can find it by clicking blue words。
Jan 12, 2010 | Acer Aspire 5100 Notebook
Forgot my password from Belkin on my mac laptop
If this is the router your referring too and you forgot your security number for the wireless can hold the reset button in on the router for 45 seconds and that will do a factory reset on the router, erasing all the security settings. You will have access to the web, but your security will be down and you will have to reset all those settings again.
Sep 27, 2009 | Apple MacBook Pro Laptop Computer with...
Forgot password on Samsung t229
Just go to phone settings in settings and reset to factory settings default. this will reset the phone to factory settings but will not clear any messages, contacts, pictures or data.. then you can go ahead and set a new password.
Apr 08, 2009 | Samsung SGH-t229 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
