Question about Garden
I think something is wrong with the carburetor. Can you fix that your self? When I try to prime it up, it won't and it won't start. Can you please tell me if I can fix this problem . Thanks AF
  • 130 Answers
Yes you can get a book and you can do this.
call around a find a book for small engine.
thats your hp
Posted on Jul 21, 2009
Does the 650 series 190 cc lawn mower have a fule filter & carborator, because mower starts and quits in about 5 secounds, where are these parts located on the motor
The carburetor should be on the right side of the engine, opposite side as the exhaust. Do you have to prime this engine to start it? If so, it is running on the prime and therefore it is not getting fuel into the carburetor or picked up by the main jet. Either way, the carburetor has debris in it and needs to be cleaned out. If the carburetor sits on the fuel tank, change the diaphram while you have it apart.
I hope this helps get you going.
Aug 04, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
My 98 Nissan Altima won't start. It has a brand new starter, brand new spark plugs, a new alternator, and a new battery, so I know it has nothing to do with any of them. The distributor was replaced at...
seems as if the system isnt priming itself when you first move the key to ON in which the fuel pump would kick on for just a moment to prime the carb with fuel if it doesnt sound like the fuel pump is starting at that moment there might be a problem with the fuel pump or a relay going to it or maybe a fuse relating to the fuel pump
Mar 14, 2017 | 1998 Nissan Altima
Mower does not start.it appears that when priming to start that it is not getting gas.how do i fix the problem
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Aug 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I can crank my murray gas lawn mower 6.5 quantum
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Wont start and lost manual for a mtd yardmachine 8/26
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets...but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Dec 24, 2009 | Mtd 22" White Outdoor Self Propelled High...
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
