Question about Cell Phones
How to cancel the security PIN that I accidentally installed
Accidentally locked channel in my TY-187 channels converter need to know the unlock code
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Oct 01, 2012 | Cell Phones
I accidentally locked my Nokia X2 phone. it asked me for the PUK # and then asked me to enter new pin number and then verify. But when I enter my own new pin it tells me it's incorrect. what do I do?
Jul 22, 2012 | Cell Phones
I cancelled my tagged account accidentally.please can i access it again.
Jan 04, 2012 | Computers & Internet
I want to knw hw i cn use my nokia 2700c security setting like wt is barring code and pin codes (and plz gives this two default codes )
PIN code is for simcard security the default is 12345...But if what you say is Locked code ,its the security of phone the default is 12345 ...about Barring code ,here is some tips...
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 | Nokia Classic 2700 Cell Phone
I hav accidentally blocked my pin. I want PUK code now to use my sim. Plz help
PUK code is a secure code that may be obtained by the Service Provider for the respective SIM.
You may call the respective Company and get the PUK.
They will also be asking the security questions.
Rate this solution and write a comment to keep in touch
Sep 20, 2010 | Cell Phones
When starting my new tomtom accidentally installed
hello. i recommend that you do a factory reset as follows: With the device turned off, press and hold the TALK/SEND, END and POWER buttons until you see a message on the screen. Release the TALK/SEND, END and POWER buttons. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset. Once the restore screen appears press Volume Up to restore the device to its factory settings or any other button to cancel. Once complete press Volume Up to reboot.
Nov 12, 2009 | GPS
Hi, my daughter has messed about with my garmin nuvi 310 and has changed the pin code. How do i reset the code so can use it again regards Gaz......
What you have to do when you forget your PIN code is to drive to the secure location that you chose when you initially set the PIN and it will unlock itself. I'm not sure how one can change a PIN accidentally without selecting a secure location. If you forget the PIN and the secure location you have no other choice but to return the unit to Garmin to be unlocked.
Aug 02, 2009 | Garmin GPS
Garmin 700 series has a PIN number I do not know.
hi dude,
i help u in this, before that i would like to provide some safety instructions to save mobile while its locked, do not enter any code after mobile lock, because it lead the mobile to unusable, just walkin to nearest certified service cnter or visit this site to unlock mobile
www.mobile-unlocker.com/
May 14, 2009 | Garmin nuvi 750 GPS Receiver
I HAVE NOKIA 6600 AND I WANT TO REJECTE CANCEL " PIN CODE " .
hello,
go to
-settings
-phone and security
look for pin code settings there and turn it off
Jan 08, 2009 | LG VX3300 Cellular Phone
Double electric oven
This is actually a feature of the oven. Holding the cancel/secure button down for three seconds puts the oven in a locked out mode so that it can't accidentally be turned on. The displays say 'OFF'. Holding the cancel/secure button again for three seconds enables it for use.
Sep 25, 2006 | Dacor ECD230 Epicure Electric Double Oven
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
