Question about AOC Computers & Internet
One day it went black, if I turn it off then on I can see a perfect picture for half a second
I had an extra AOC monitor and it works fine but does not have the perfect picture I used to have with the old one. i can recycle it but seeing that perfect picture for a split second tempts me to believe it's still good
  • 44 Answers
If this is a LCD monitor, most likely the invertor or the bulb is not working correctly. If you shine a flashlight at the monitor you should be able to see the image. What has happened is the back light is not lit to display the image. If you are handy at repairing electronics you can swap invertor and bulb from the other monitor if they are the same model and size. It may require some soldiering though.
Posted on Dec 07, 2016
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
AOC vertical white line moving across the screen
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
Jan 31, 2012 | AOC Computers & Internet
New AOC monitor. No sound . when i insert dvd which was in the package it just promotes AOC products
Did you plug the sound sable into the audio out port on your computer?
The VGA and DVI monitor cable/plugs do not have sound capability so if there are speakers on your monitor they need to get the sound signal through a separate wire.
HDMI can send sound so if your monitor is hooked up via HDMI it should be able to pass sound as well (at least in most circumstances).
Mar 12, 2011 | AOC Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AOC 26" LCD 619Fh Problem
Go to "Picture Boost" option in the "OSD window". Then turn on the "Bright Frame" option and after that make the "Frame Size" to 100. That's it now you can get a perfect sharp image...it worked for me.
Mar 07, 2009 | AOC LM729 17" LCD Monitor
My Olevia LT37HVS 37' was working fine all day and turned to black screen.
It is either the fluorescent backlight source for the LCD panel or its associated power supply failing.
Nov 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Computers & Internet Logo
55 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
