Won't run period
HCM-300T just run. Seems like there is no power. Wall unit functions so it's the machine.
    Master:
  • 252 Answers
I don't know what could be wrong, but here is the manual for it. It may have a trouble shooting guide in it, or a number you can call customer service that may help you.
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/cool_moisture_humidifiers_model_hcm300t_hcm310t_hcm315t_1.html?p=1
Posted on Dec 07, 2016
Honeywell HCM-300T humidifier won't turn on. How do I fix it?
You should put the correct filter in it, or find the little plunger and put a small piece of duct tape over it so the machine "thinks" the right filter is installed.
Mar 21, 2017 | Cars & Trucks
No water
well these dont work in winter 1st off if heater is on were u from try to wigle the water buket on it just right so sits in and turns on sum sensor toucjy the way they sit in
Jan 19, 2008 | Honeywell HCM-300T Humidifier
When I first turn on my unit water comes out and wets my floor.
Does it have a collection tray , that needs to be emptied first.
Mar 15, 2015 | Honeywell HCM-300T Humidifier
I need a tray for hcm 300t. the filter sits in this tray, my tray has a crack and i would like to replace it
Why not just repair the crack with a product like Devcon Weldit? Stuff works great for sealing cracks and is waterproof.
Apr 07, 2012 | Honeywell HCM-300T Humidifier
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
Should anything be done to 305t before it retires for the summer?
Yes, there is. Routine maintenance is important. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank with it. Run the humidifier until the tank is 1/2 empty. Then empty the remaining solution and refill the tank 1/2 way with Bottled Distilled Water and run it until it's empty. This will flush the entire system of the previous 50/50 solution. If you can access the fresh air intake, clean that using a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the accumulated dust. Be sure the unit is completely dry before storing it.
If more folks would do this, they wouldn't have problems in the Fall & Winter.
Apr 12, 2011 | Honeywell HCM-300T Humidifier
Honeywell HCM-300T QuietCare 3-Gal UV Tower Humidifier Fan/Motor seems quite noisy and occasionally squeeky. Is this normal?
no, it will be needing to be opened up to check if anything is interferring with fan operation I.E. broken fan, motor bearings, anything touching fan
Jan 31, 2010 | Heating & Cooling
Humidistat problems
The ability of the humidifier to maintain a given moisture content in the air is far more difficult than a heat or cooling unit to heat or cool the air.
Moisture vapor has far more energy to seek dryer air, than tempered air. So the moisture seeks and finds dryer air quickly, whether it be through stair and door ways, or through cracks and seams in walls and doors/windows, or through non vapor barrier surfaces.
The only way the unit would be able to achieve a humidity level as stated, is for the unit to be placed in a vapor-tite room that has a minimal of leakage.
You could put more humidifiers in the space, or more and larger humidifiers in the space, to try and overcome the vapor moving to other areas of the space. But unless you have a fairly vaportite space, it is unlikely the unit is under capacity, and the only way to test what capacity is needed is to take humidity measurements.
Reply back with any questions you may have.
Feb 03, 2009 | Honeywell HCM-300T Humidifier
Water Tank leaks all over the floor
This happened to me the second night of use.  Water all over the carpet and a dripping vent. I called customer service and they told me to remove the tank and filter, and run unit dry for an hour or so. Then restart it.  Worked fine after that.  I think we may have bumped it which is said to be the cause of most leaks.  Bummer is that after 5 night of use the grip on water tank slipped and the tank is in pieces.
Nov 12, 2008 | Honeywell HCM-300T Humidifier
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
