Question about Crafts & Hobbies
First time using cricut imagine...the cricut is turning on but the welcome screen options are not appearing
2 Suggested Answers
CricutAddict
  • 13 Answers
SOURCE: my cricut will turn on but the lcd screen is black
Sounds like you have a bad connection in there. I would contact Cricut for tech support; they will probably be able to send you another machine to replace yours. Mind you they will put a charge on your card and remove it when they receive your machine. I hope this helps if you need their contact number get back in touch with me.
Posted on Mar 25, 2010
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Cricut expression 2 has no power, will not turn on
    Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
    Nov 05, 2011 | Cricut Expression Cutting Machine
    How do I update my cricut imagine to accept the gypsy update?
    jut go to this site and watch the video www.aboverubiesstudio.com/.../cricut-imagine/cricut-imagine.../2354/ try this one hope this will help you.
    Oct 23, 2010 | Computers & Internet
    How to restore Dell Dimension 8200 to original factory setting?
    1. Insert the Operating System CD into the CD or DVD drive.
    Close any program or utility that may start to run after you insert the CD into the drive.
    note.gif HINT: The CD that you need to place in your CD or DVD drive is titled Operating System.
    1. Turn off the computer, and then turn the computer on again.
    2. When the blue Dell logo appears, press immediately.
    If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down the computer and try again.
    1. Use the arrow keys to select the CD-ROM option, and then press .
    2. When the Windows XP Setup screen appears, press to select To set up Windows now.
    3. Read the information in the License Agreement window, and then press on your keyboard to agree with the license information.
    4. If your computer already has Windows XP installed and you want to recover your current Windows XP data, type r to select the repair option, and then go to step 15.
    If you want to install a new copy of Windows XP, press to select the fresh copy option, and then press on the next screen to select the highlighted partition (recommended). Then follow the instructions on the screen.
    The Windows XP Setup screen appears and Windows XP begins to copy files and install the devices. The computer automatically restarts multiple times before it requires additional input.
    1. When the Welcome to Microsoft screen appears, click the green arrow icon at the bottom of the screen to continue. Follow the on-screen directions to finish.
    2. When the Regional Settings screen appears, select the settings for your locale, and then click Next.
    3. Enter your name and organization in the Personalize Your Software screen, and then click Next.
    4. If you are reinstalling Windows XP Home Edition, enter a name for your computer when the Computer Namewindow appears, and then click Next.
    If you are reinstalling Windows XP Professional, enter a name for your computer and a password when theComputer Name and Administrator Password window appears, and then click Next.
    1. If you have a modem installed and the Modem Dialing Information screen appears, enter the requested information, and then click Next.
    2. Enter the date, time, and time zone in the Date and Time Settings window, and then click Next.
    3. If you have a network card in your computer, select the appropriate network settings. If you do not have a network card, this option does not appear.
    Windows XP begins to install its components and configure the computer. The computer automatically restarts.
    2. Remove the CD from the drive.
    3. Reinstall the appropriate drivers. See "Reinstalling Drivers."
    4. Reinstall your virus protection software.
    Sep 11, 2010 | Dell Dimension 8200 PC Desktop
    My cricut will turn on but the lcd screen is black
    Feb 11, 2010 | Provo Craft Cricut Disney Font Cartridge
    Cricut makes loud grinding noise and will not turn roller bar
    My wifes' cricut seems to have had the same problem. Try turning off the power, then manually slide the cutting carriage to the left look inside to the right. you should see a red button pull on it until it clicks. power up the cricut and see it it works. it solved the problem for my wife.
    Jan 02, 2010 | Provo Craft Toys
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Dials not working
    You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
    Mar 13, 2009 | Provo Craft Cricut Disney Font Cartridge
    Crafts & Hobbies Logo
    131 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
