Question about Toys
How to play hand switch - Toys
Kill switch wiring
depends... most 4 strokes use a single wire from coil to ground kill system. I.E. wire goes to the kill switch ( key ) then over to ground ( safety switches come into play when dealing with riders, ztr's and big mowers. hand held equipment like weed eaters can either ground at the kill switch or go back to the block for grounding.
Oct 20, 2013 | Garden
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
My nokia 6500s-1, the memory card drive is not picking.
Hello.If your memory card is ok. The only thing you need to do is to check the back cover.On the back cover left hand side near the memory card location there is a switch (pin) which plays the mmc leap switch to press or giving connection to the phone.So, first remove the back cover and open the Gallery in your phone and press the Pin (switch) which is located in the left hand side of the memory card slot.If it works just put a piece of paper/ something to press the switch permanently.Otherwise contact mobile repairing shop.Good luck
Mar 04, 2012 | Nokia Cell Phones
I have a 1998 QPS Interactive fruit machine(pacman) was just wandering how to change it from free play to money play
There should be a couple of wire that need to be plugged in if you havent already done that, And after that you might have to push the red reset button.
Aug 02, 2009 | Video Game Consoles & Games
Bought it 2nd hand
After conducting extensive research, I have concluded that there is no ID and/or password to reset. According to my research, this is an "unmanaged" switch. It's plug-and-play all the way.
Jun 11, 2009 | D-Link DES 1016 16-Port Ethernet Switch
Hand Controller Switch off
Hi--Thanks for your e-mail. I have found out the cause of my problem with the TV screen dimming after about 5 minutes when the hand controller goes off. It was me--by pure chance I discovered it was due to me turning on the WII console using the hand controller and not the "Mains" switch on the console, so when the hand controller switched off, the display on the TV went into "Standby". It even did it when displaying the Home screen so it was nothing to do with the game. All I did was switch on the console with the main switch and then switched on the remote, I left it untouched for about 20 minutes and it was fine.Perhaps this little tip might come in handy for some other "Twit" like myself. Thanks for your offer of possible help. Alan Marsham.
May 01, 2009 | Nintendo Wii Console
Wii has frozen playing guitar hero
Hi. I got the same thing playing GH but without the nunchuck. Use the hand controller to re-sync. Press the sync button on the console FIRST and then the sync button on the hand controller SECOND.
I sat for hours trying to work it out - and it cleared the problem within seconds. Hope it works for you too.
Feb 20, 2009 | Nintendo Wii Console
Problem with PSP "home" button
Hiya i have that same issue. when i watched my hands intensely i found that i actually do tap the button accidently and dont notice it if im too involved in a game if you make sure your left hand steers clear of the 'home' button im sure you will notice a difference
Jan 16, 2009 | Sony PlayStation Portable (PSP) Console
Set top boxes for mmds ireland
hi all,all boxes supplied by the vendor are not plug and play
but dont panic as help is at hand at 4 have the latest software to download.
Dec 29, 2008 | StarView SV211K 2-port KVM...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
