Question about Dishwashers
My zanu. dishwasher drainage hose is blocked
4 Suggested Answers
SOURCE: Drainage blocked on Whirlpool ADG
two things to check
if drain is plumbed nito a spigot on the sink trap, check that ther spigot and drain hose are not blocked - this is very common
also see if you can get to the drain pump and check there is nothing jamming the impellor. also if you have access to a multimeter, check if the drain pump is powered up
Posted on Sep 06, 2008
  • 1891 Answers
SOURCE: bosch front load washer display says drainage
look for a front plate lower right corner / remove plate and inside is 3 in drain cleanout . ccw will remove and clean basket . cw to reinstall . should correct problem. mm
Posted on Dec 03, 2009
Testimonial: "The help was perfect. Thank you."
Macmarkus
  • 2605 Answers
SOURCE: The "Drainage blocked" message appeared - how do I
Welcome to FixYa.
Based on your post,
this is usually associated with a plugged drain or pump as you mentioned.
These are the steps I'd suggest you take to move forward...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful...I usually cover the edges with electrical or duct tape or wear welders gloves).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
( you should also see a ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
macmarkus_31.jpg THIS RELEASES THE DOOR LATCH IF PULLED
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap.
Hopefully you'll find the item/debris that initiated your post here.
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Mar 20, 2011
Plugged drainage on dishwasher
clean your filters on the bottom tray. the pump impeller might be jammed or the drain hose might be kinked or be blocked hope this helps
Jan 05, 2014 | LG LDF6920WW - Dishwasher with...
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Wont drain
The two major reasons for no drainage in your dish washer is either Food & debris are blocking the drainage basket or Food is clogging the drain hose. Check out this article which would assist you do some steps to get it cleared.
http://household-tips.thefuntimesguide.com/2006/07/fix_dishwasher.php
Please accept the solution if this assisted you.
Thank You for contacting Fixya.com
Mar 01, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
I have a really bad smell and stagent water in my dishwasher, what do u think could be wrong?
Make sure the drain hose is not blocked or pinched.Also check where it drains into your sink pipeing to be sure food isnt blocking the drain way.
Its eather the drainage path is blocked or the pump stoped pumping.
Also, the drain hose must be installed so as to have a high spot higher than the sink drain or the water from your sink will be able to "run down hill" or drain into your dishwasher. Take a look and see!
Oct 31, 2009 | Dishwashers
Dishwasher not draining, how to fix it?
Make sure the drain hose and the under sink connection is not blocked with old food.If nothing is blocked on the drainage system then the water pump may be weak.I hope this helps
Sep 07, 2009 | GE Dishwashers
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Dishwasher
you can buy the drainage hose ( B&Q) by the per / m if you can not install a drainage pipe closer.
May 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwasher doesn't drain
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
Oct 06, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
