NEW Kenmore oil filled radiator heats up when in the OFF position- waited a year to use for first time- warranty no longer applicable
  • Heating & Co... Master
  • 2,598 Answers
I would contact the company and explain the problem .
Posted on Dec 07, 2016
Just stop working.. one year old
It should still be in warranty, even if it is slightly past the 12 month period a phone call to the supplier might bring a pleasant surprise. It really should have lasted longer
May 27, 2015 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
I need a safety user manual for a delonghi rapido oil filled radiator
probably need to take radiator back to store and trade for another one, most time when you buy new electric appliance all inside paper work like warranty,operation instruction manual should be inside package if not, need go back to the store where you purchased radiator, they should give you another operation instruction manual and warranty paper work or give you whole new entire radiator take back the other radiator.
Dec 12, 2011 | Heating & Cooling
Reposting: I have a lakewood oil filled radiator heater that will NOT turn on. Is there someplace or something I can do to have it fixed?
Depending on its age, you can return it to the place of purchase. Because the cost of repair will almost certainly exceed the cost of replacement, it is not a practical option. If you have a friend who is comfortable with electrical systems, you could try that. There are a few brands of oil filled heater that have recalls. The consumer safety bureau or the manufacturer may have information about a recall on your product. This is a good time of year to purchase a new one as many stores are just starting sales on heating appliances. Farmerbear at FixYa
Oct 23, 2010 | Lakewood Oil-Filled Electric Radiator...
Coolant level drops, not visible in oil, no leaks on grd, changed thermostat, rad cap, did flush and refill, no heat at any RPM.Also, during the last 2 days it insists on red lining the temp guage when...
did you drain coolant before you changed the thermostat? If you did and you just filled up directly after, the system didn't get bled. You have to have vehicle running with radiator cap off, then fill and let it run through, fill more and more until it doesn't get any lower anymore, you can also gently squeeze the radiator hose when pouring coolant in also helps bleed the system.
To properly fill and bleed the raidiator and coolant system, should actually take about 10 - 15 minutes.
When you first pour fluid in it will go to top of radiator or reservoir, then it will slowly drain into engine block, then you add more and patiently wait for it to drain in engine block, keep doing this until the entire system is full and level no longer drops.
Mar 04, 2009 | 1999 Dodge Ram 2500 4WD
Leaking Oil from the front
DONT BUY A NEW ONE THEY ARE EXPENSIVE ... THEY PUT OUT VERY LITTLE ACTUAL BTU'S OF HEAT ...IT WOULD BE DANGEROUS TO TRY AND BRAZE ANY LEAK POINTS AND THE OIL IS NOT CAR OIL AND NEEDS TO BE FILLED TO FACTORY SPECIFIED LEVELS. (THESE ARE NOT MEANT TO BE RE-FILLED OR DOES THE OIL USUALLY DIASAPATE). OIL HEATERS OF THIS TYPE USE PLENTY OF ELECTRICITY. I SUGGEST A "HIGH QUALITY, THICK CASED, WITH TILT SAFTY, ELECTRIC SPACE HETER WITH A FAN. THEY HEAT PROBLEM AREAS SAFE AND EFFECTIVELY.
Apr 26, 2007 | DeLonghi 9707 Oil Filled Radiator Heater
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
