Question about Bernina Sewing Machines
I have a Bernina 830. Using #03 foot....bobbin thread through the hole in the arm of the bobbin. Why does it not go in reverse to finish the buttonhole?
  • Bernina Master
  • 12,495 Answers
If it is the older Bernina 830 Record, could be some of the parts have seized due to lack of oil. Frequently, seldom used functions (levers, dials, feed dog control) are the first signs.
Wheel on right side that controls the needle up and down is very tight...
Be sure to move the dials/levers and apply oil there as well.
Posted on Dec 07, 2016
How to remove the top cover of Bernina 830. My machine keeps telling me to rethread. It stitches about 10 stitches then stops
Which Bernina 830 are you referring to? (Yeah, it was crazy of Bernina to use the same numbers to identify different models...). There is the old Bernina 830 Record and the new computerized Bernina 830.
Have you tried rethreading the machine? If so, be sure to ALWAYS RAISE the presser foot. Verify the thread path is correct.
Apr 10, 2018 | Bernina Sewing Machines
How do I remove the free arm plate from my Bernina 830
Not sure I understand your question. Is that the old Bernina 830 Record? Removing the extension table will reveal the free arm. On the other hand, if you want to open the free arm to clean and oil, look inside the bobbin department and there is a little metal tab on the left top side that, when pushed, will release the cover.
BERNINA Sewing Systems
For the newer computerized 830, here's the manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjB0Z7Xyb_YAhVM8WMKHeXSB8MQFghIMAI&url=https%3A%2F%2Fwww.bernina.com%2FBERNINA%2Fmedia%2FSupport%2FSewing_Quilting_Embroidery%2F8_Serie%2FBERNINA_830%2FDocuments%2FEN%2F032299-53-04_1204_B830_EN_online.pdf&usg=AOvVaw3AHGuyLUld3qgcmW-8Fr-Q
Jan 04, 2018 | Bernina Sewing Machines
Why can't I reverse stitch properly on Bernina 1008 when using zipper foot?
please check that the foot is attached on the drop arm in the correct position as it sounds like the foot is not down far enough to reach the base plate I have had the same problem when you have more than one foot in your spares box eric
Dec 12, 2017 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
I have an older Bernina 830. I am having what seem to be tention broblems with the stiches not forming and lots of thread being produced. The adjoining problem is that there is a rattling when I attem
What you're describing is commonly called a 'bird's nest' for fairly obvious reasons. There are, unfortunately, a number of things that can cause it.
Troubleshooting steps:
1. Clean it! I've seen machines that haven't been properly cleaned for years. If there is lint, dust or dirt in the bobbin area especially, the looper won't work correctly and the stitch won't form. Be sure to take out the bobbin when you do this.
2. Oil it. Follow your manufacturer's instructions for this. If you don't have a book, contact Bernina and get one.
3. Change the needle and check the tensioning disks to be sure that no lint, old thread, etc. has got caught in it.
4. Adjust the tension. This can be tricky, so take it in small increments. Here, again, a manufacturer's book is a godsend.
5. If none of this avails, or it only partially fixes the problem, take it to a reputable service center (most fabric, quilting, etc. stores have or know someone) and have them adjust the timing. Most machines need this done every 1-5 years depending upon the usage.
Good luck with it. I wish I had an older Bernina, they're good machines.
Feb 14, 2015 | Bernina Sewing Machines
I have Bernina 830 embroidery machine. I'm still a novice with this machine. An upper thread broke and could only be removed from the right side. I know that this is a NO NO but I had no choice. I r
Do you have a manual?
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Bernina+830+manual&_sop=15
You may need some cleaning, oiling or maintenance?
Tips for cleaning and maintenance:
Oil the hook after having used the content of 3 to 4 bobbins. The machine
screen will display a reminder
Increasing noise of the motor and/or irregular
stitch formation can also be an indication that oiling is necessary
Remove any lint from the hook and the bobbin area, then remove the stitch plate
See instruction manual chapter Maintenance/Cleaning
YouTube videos:
https://www.youtube.com/watch?v=mlBNy33bd3U
https://www.youtube.com/watch?v=mV4z3EAyMz4 Bernina 830 or 880 Thread Nesting Troubleshooting
Feb 08, 2015 | Bernina Sewing Machines
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
Old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Aug 29, 2009 | Bernina Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
