A/C I have a 02 lincoln ls, and when i try turning on the ac it blows regular air, but if we leave the car on for 30-45 minutes on without turning it off it starts to blow cold air, anyone with info please help, the heat out here is unbareable!
BAD RELAY SWITCH
Posted on Jul 20, 2009
My 02 lincoln ls has no heat
Or,it might be low on antifreeze or have air in the system,but it probably IS what Matt saays above. don-ohio
Dec 29, 2012 | 2000 Lincoln LS
Ac clutch relay 2001 lincoln ls location
drivers side next to the battery
Sep 11, 2012 | 2001 Lincoln LS
2005 Lincoln Ls...white smoke coming from under hood. Not visibly leaking fluid and no sensor light has gone off. Blows hot air even when you turn AC on. So confused.
Hi there:
I would say that the problem is going to be one of the following:
1. Thermostat
2. Radiator
3. Water pump
4. Head gasket.
Now I would have to lean toward thermostat or head gasket.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 27, 2012 | 2005 Lincoln LS
Air conditioner blowing hot air
Blowing hot air when set to A/C is almost always a stuck blend door, dead blend door actuator, or a cracked or disconnected blend door actuator vacuum line. The blend door is inside the a/c ducting under the dash, but the actuator will be accessible outside the ducting.
Jul 05, 2010 | 2000 Lincoln LS
2000 lincoln ls ac blowing hot air I've replaced the heater control valve
You need a scanner to diagnose,not a code reader.
The DATC Module ( Dual Automatic Temperature Control Module) is a possible
May 21, 2010 | 2004 Lincoln LS
2004 lincoln ls ac blowing hot air hotter on one side ac running
Your issues can only be solved with the use of a Scanner and Diagnostic Trouble Charts and System Charts.
Everything is Electronic and complicated. I just looked at my LS Shop Manuals.
I would prefer you went to a local shop,but you could go to a dealer.
Without a Data Base some shops subscribe to,they won't repair this vehicle,it is way too high tech
I own a 2004 V8.
May 13, 2010 | 2005 Lincoln LS
Heat blows out driver vent when ac on
this problem is caused by a defective air temperature control blend door actuator motor, it is about center of dadsh in air ducting, it moves the door that diverts air for cold from ac or hot from heater, you must remove the dash to repace it, about a 15 hour job fotr a home mechanic with a factory repair manual, nearly imposs without one.
Sep 04, 2009 | Lincoln LS Cars & Trucks
Air conditioner blow heat out of the left dash vents
Get your ac filter replaced. My car did the same thing for a year until I figured out what the problem was.
Jun 15, 2009 | 2001 Lincoln LS
Ac not working blowing hot air
Check to see if your radiator is holding pressure. Fell your radiator, let it idol and make sure nothing is leaking. If you have a small leak, try running through a bottle of MAC's(or any brand) leak stopper. It should work. But make sure you follow all the instructions, when it says let it idol for 30 minutes, let it idol for 30 minutes. I have seen/found Lincoln LS's seem to have quite a few leaks that pop up on it's radiator, the plastic thermostat housing and it's cap. Have fun.
Jun 04, 2009 | 2003 Lincoln LS
Ac blowing hot air on 2005 lincoln ls. just sarted today
Needs to be recharged and you more than likely have a leak somewhere
May 31, 2009 | 2005 Lincoln LS
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
