Question about Kenmore Dryers
Is there a circuit breaker in the dryer itself?model Kenmore C97884180
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
  • 330 Answers
SOURCE: HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Posted on Jul 06, 2008
  • 1028 Answers
SOURCE: kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Posted on Sep 18, 2008
  • 117 Answers
SOURCE: Kenmore Heavy Duty Dryer
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Posted on Feb 26, 2009
After power outage dryer will not come on model # 96573220
Hello Edward, Is it possible that the electrical circuit breaker is tripped in your breaker box? Try shutting the breaker off and turn it back on.
Feb 23, 2014 | Kenmore 60172 Electric Commercial Dryer
I have a kenmore Elite dryer it was working fine than blew the circuit breaker, I unpluged it reset the breaker pluged it back it and it sparked and blew the breaker again. I disconnect the motor in the...
If the dryer is tripping the circuit breaker, it's possible that the circuit breaker itself is malfunctioning. or a wire is loose to breaker.
There could be a loose connection in the outlet. A loose connection in the outlet could consist of wiring that is not functioning and is unable to properly manage current. The current needed by the dryer is being mishandled by the loosely connected outlet and drawing more power from the electrical system, tripping the circuit breaker. check outlet to find out !
Mar 29, 2012 | Dryers
Kemore 70 series electric dryer not heating up
Might be the heater or a heater limit or the timer itself. It also could be the wall outlet or circuit breaker. It most likely is the heater itself though. Repair videos and manual on kenmore dryers
Mar 05, 2012 | Kenmore Dryers
I don't have heat to my dryer.
Make sure that Front of the dryer is not blocked, Air flow is needed to dry.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty heating element.You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
We have a kenmore electric dryer runs with no heat. repair manual said to check fuses. House panel has circuit breakers none tripped manual says there are two house fuses in the dryer circuit. If one of...
Older fuse panels would have two fuses, one provides power from each 120 volt leg in the panel, therefore providing 240 volts for the heater coil. The motor in the dryer only requires 120 volts, so it may possibly still run if it is on the side with a good fuse. In newer panels that have circuit breakers, you may only have a single handle, but the breaker is a 240 volt breaker (which controls both 120 volt feeds at the same time). You will likely notice that this and all other breakers that are 240 volts are twice the width of a single 120 volt breaker. There is no "second fuse" for you to check, as the circuit breaker takes the place of both fuses in an older style panel.
If you are able to confirm that you have good power at the power connection at the back of the dryer (120 volts between black and white, 120 volts between red and white, 240 volts between red and black wires), then that typically only leaves the heater coil itself or the timer to check. Check continuity on the heater coil first, and visually inspect it for a broken or shorted coil. It is usually the culprit.
If the coil checks ok, carefully check the voltage at the terminals that feed power to the coil. Depending on the model, there may also be a thermal fuse or thermostat that is inline with the power feed to the coil itself. Check this to make sure that it has continuity as well.
I hope this helps you with your repair troubleshooting. Good luck!
Mar 13, 2010 | Kenmore 62602 Electric Dryer
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
My dryer is not heating, but all other things works find.
CHECK FIRST TO SEE IF YOU ARE GETTING 220 VOLTS TO DRYER ITSELF WILL RUN ON 110 BUT WILL NOT HEAT , CHECK FUSES IF ANY CIRCUIT , RESET BREAKER EVEN IF IT DOES NOT APPEAR TRIPPED CHECK FOR 220 VOLTS @ SOCKET THEN TALK TEAR DOWN
Nov 25, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
