The calculator does not show decimal when square rooting non-prime numbers. (fx-CG20)
For example, when I type square root 3, it shows square root 3 as an answer instead of 1.73... is there a way to change the setting so that it would be answered in decimal?
  • Office Equip... Master
  • 8,068 Answers
You should feel happy that your calculator can perform some exact calculations. If you do not want the exact values you can press the SD key. You can also press SHIFT EXE rather than EXE alone.
Posted on Dec 10, 2016
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
Feb 03, 2015 | Casio fx-115ES Plus Scientific Calculator
Square root in answer
Press SHIFT [SETUP] 1 to set the MthIO mode.
Try calculating the square root of 8 (press sqrt 8 =). Do you get 2sqrt2?
Mar 03, 2014 | Casio FX-115ES Scientific Calculator
I have a casio fx-115ES and I want to do a cube root without answering in decimal forms
Sorry, but the fx-115ES can only display square roots in radical form. Cube roots are beyond its symbolic capabilities and will always be in decimal form.
Mar 08, 2013 | Texas Instruments TI-86 Calculator
Fx-115es radical notation
This calculator can show the results in radical form if it involves square roots. The 4th root of 243 is 3 times the fourth root of 3, which unfortunately is beyond the calculator's capabilities to display in radical form. Try taking the fourth root of 3 (or equivalently, the square root of the square root of 3) and you'll see the calculator display the result in decimal.
Feb 06, 2013 | Casio Office Equipment & Supplies
The calculator can show the results in radical form if it involves square roots. The 4th root of 243 is 3 times the fourth root of 3, which unfortunately is beyond the calculator's capabilities to display in radical form. Try taking the fourth root of 3 (or equivalently, the square root of the square root of 3) and you'll see the calculator display the result in decimal.
Feb 06, 2013 | Office Equipment & Supplies
How to use square root for non square numbers for casio graphing calculator
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
Jan 17, 2013 | Casio FX-9860GII Graphing Calculator With...
On my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
Oct 31, 2012 | Office Equipment & Supplies
How do I simplify a cubed root of a number on the fx-300ES?
It can handle square root but if result requires too much display space it will be displayed as a decimal.As to higher order roots such as cube , 4th and higher they are displayed as decimal. Sorry, there is nothing you can do about it.
Apr 18, 2012 | Casio fx-300ES Calculator
How do I get the answer into another square root. for example- Square root of 6 times square root of 15 is 3 times the square root of 10. But on the Casio FX9750GII it comes up as a decimal, how do i...
You cannot. The calculator does not have the Natural Display (math display) feature. I have heard that you can flash it with the OS of an FX-9860GII. At your own risk.
Sep 16, 2011 | Casio FX9750GII Graphic Calculator
How to find nth root using Casio FX-83ES
You use the power root function key accessible with the key sequence [SHIFT][X ^]. I am inserting a screen capture from the manual to show you the sequence.
On the third line of the capture (power root) is the key you must press. In the small rectangle to the left of the radical sign you enter the order of the root: 2 for square root, 3 for cube root, 4 for 4th root and son on.
To calculate the decimal log you use the [LOG] key as shown on capture. For natural log (ln), use the [LN] key. The argument (2/3) in your example should be enclosed inside the parentheses.
Jun 04, 2010 | Casio fx-300ES Calculator
299 people viewed this question
k24674
jasbo
jasbo
