Question about Bissell Vacuums
Bissell Green Machine 7700. What is the strip near function power buttons, rear section of unit. The behind the strip is a hole after the strip is moved.
How can I download Bissell Little Green Clean Machine manual?
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ... > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' > > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL® > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on ... (including all accessories and manuals) ...
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    • 4 MIN
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Little green machine will not spray cleaner
    Have you checked the tiny hole that the spray comes out of. I have one and sometimes it becomes clogged. I take a small needle and run it thru it.
    Oct 09, 2014 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Bissell big green clean machine extention hose not spraying
    Hey, sorry you're having difficulty with the spray on the hose.
    Here's a quick link to troubleshooting steps to assist you:
    Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
    Make sure the hose solution line is connected, wet clean button is pressed, look for two small o-rings on the end of the fitted end of the hose solution line, and run the machine for 5 minutes with all three buttons engaged to dislodge any clogs from the heater.
    Here's a link to one of our BISSELL Authorized Service Center if you continue to have difficulty.
    Nov 13, 2012 | Bissell 7700 Big Green Complete Vacuum,...
    Reset button for bissell
    - Make sure the power cord is plugged into a functioning outlet to check for power.
    - The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
    - With the machine turned off and unplugged, check the pre-motor filter and the Airetightâ„¢ HEPA filter for debris. Reduced air flow from dirty filters or clogs will put greater stress on the motor, increasing the possibility for overheating. The pre-motor filter is located underneath the canister of the vacuum in the pull out tray labeled "filter". This may be hand washed in cold water with mild detergent. Reinstall this filter when it is completely dry. The Airetightâ„¢ HEPA filter cartridge needs to be replaced and cannot be washed. This is located on the side of the machine inside the filter grill.
    NOTE: Ensure the machine is turned off and is unplugged before checking the following.
    - Empty the dirt cup. Remove the lower portion of the cup and clean the screen and check the center tubes for dirt accumulation.
    - Check the dirt inlet. This is the opening located behind the canister and is only visible once the canister is taken off the machine.
    - Detach the hose from the machine by twisting the hose collar counterclockwise. Push a broomstick into the hose to push any obstruction to the end of the hose where it can be removed.
    - Check the clear diverter area at the back of the machine. When the hose wand is removed from the base, the diverter should be in the up position. If a clog is visible near the diverter, remove the divertor cover by removing 7 screws and clear the obstruction.
    NOTE: Be careful not to dislodge the gasket.
    - Recline the machine back and roll it over so the backside is facing up. Remove the bottom 4 screws from the diverter cover to loosen, and straighten the foot hose. Look through the hose for obstructions. Push a broomstick through the lower hose to unclog this. (Any obstruction should exit through the suction path at the brush roller).
    NOTE: The Healthy Home Vacuum is equipped with a Thermal Protector feature to prevent the motor from overheating. If the motor becomes too warm, the thermal Protectors will activate and the machine will shut off automatically. If the Thermal Protectors activate, please do the following:
    - Turn off and unplug the vacuum. Thermal Protectors will reset automatically in approximately 30 minutes.
    - Clear any clogs.
    If you continue to experience no power, please take your machine to a local BISSELL Authorized Service Center. BISSELL supports your machine with a five year warranty.
    To locate your nearest BISSELL Authorized Service Center, please go to Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
    Aug 27, 2010 | Bissell 16N5 Upright Vacuum
    NO power no ****
    If you have your User Guide look in that under the trouble shooting section and see what it says, I'm not sure if yours has a (reset) button on it if it does then press that and then retry it.
    Sep 29, 2009 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    I need the instructions for the Bissell Little Green Machine Model 03041 J03041.
    BISSELL User’s Guides can be downloaded at
    On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
    User Guide will be displayed as a PDF file.
    Jul 14, 2009 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Vacuums Logo
    37 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
