Question about Frigidaire Refrigerators
Frigidaire wu. lra18hmu2 s/n kk23402482 mamuf 08/12. fan won't shut off. Is it the control board p/n PS3496408
    Master:
  • 552 Answers
The control board controls everything. It also reads inputs to determine how to exert this control. A thermistor tells it what the temp is. If either are defective the fan can be out of control.
Posted on Dec 09, 2016
Mine is flashing EFO90 what does this mean it a front load washer by Firgidaire
Frigidaire Refrigerator Error Code = EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Dec 27, 2016 | Frigidaire Washing Machines
Why isn't my frigidaire heat/air not blowing warm air at all! Model LRA18HMU2
If the blower is not running its likely not setup properly on the tstat. Be sure its setup for electric heat with forced air. Tstat controls the fan
Nov 23, 2016 | Frigidaire Heating & Cooling
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Why won't exhaust fan shut off?
you have to replace the switch or control board
Jan 23, 2016 | Frigidaire Microwave Ovens
Why won.t the fan on my microwave jkp86sh4ss shut off.
You probably have a bad relay on the main board.
Feb 07, 2015 | Kitchen Ranges
Model fsc23f7dsbc ref replaced control board now ref flashing e f
Good Afternoon friend, thank you for your inquiry!
Based off the information you have provided you replaced the control board and continue to experience troubles with your Frigidaire refrigerator. Normally an "EF" error code stands for evaporator fan circuit failure. This could be an issue with your evaporator fan or main control board. I would suggest consulting with a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this helps to some degree. -Matt
Sep 24, 2014 | Frigidaire Refrigerators
FAN WON;T SHUT OFF EVEN WHEN UNIT IS TURN OFF WINDOW UNIT
The switch may have rusted a bit and won't let the switch turn off. Sometimes a whack with the side of your hand might jar it loose and turn off. Or the switch is bad and needs replacement. You probably got it at Lowes. Ask them to suggest a good repairman.
Jun 14, 2014 | Frigidaire 5,000 BTU 9.7 EER 115 Volts...
I have a frigidaire upright frost free freezer model number is FFU2065FW3 I put in a new electronic temperature control Board and when I plugged the freezer back in, the control board was flashing "E" and...
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Apr 03, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Fan on microwave
The "hood fan thermal cutout" is designed to turn on the hood vent exhaust fan if the stove top temperature gets too high.
If that fan comes on and stays on, the hood fan thermal cutout may have shorted, needing to be replaced, or its driving relay on the control board may be shorted.
If that's the case, we regularly repair such control panel assemblies nationwide for $39.95 postpaid.
You can find the Frigidaire manual that may help you here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Mar 14, 2010 | Frigidaire FMV156DC Microwave Oven
Refrigerators Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
