Question about Kenmore Dryers
Hello, we have got instructions for installing our Kenmore dryer belt - need help on finding video
How do I get access to kenmore dryer model 8873 to change belt and thermal fuse
PartSelect.com has some VERY good videos and sometimes user instructions for lots of home appliances. I've used it (and bought parts from them) for a dishwasher and dryer so far. Their videos have been priceless. I'd try them first and then check back here if you don't find what you need.
Jan 02, 2015 | Kenmore Dryers
Belt broken
how to open a dryer:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Jan 10, 2011 | Whirlpool Dryers
I need a diagram describing how the tub belt is routed around the motor and tensioner
Hello
Hope this video will help you to replace the belt in your Kenmore Dryer:
Nov 15, 2010 | Kenmore 67632 Electric Dryer
I have Kenmore dryer, which was running fine until the last load. The hot air is coming inside, but clothes are not drying since it was not turning around. I cleaned the vent, please let me know, what...
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 19, 2010 | Kenmore 63942 Dryer
How do I install idler and pulley assembly on a Kenmore 70 Series dryer??
your local appliance parts store would be glad to help u with this . on the back of some belt paks u will find instructions. good luck hope this helps
Nov 17, 2009 | Kenmore 62602 Electric Dryer
I need to replace the dryer belt from a Kenmore washer dryer comb
Remove the top lid, then the front panel to access the drum and belt. Unplug the dryer first.
Jun 07, 2009 | Kenmore Dryers
How do i?
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Apr 05, 2009 | Kenmore 63942 Dryer
I need instructions to install belt on my clothes dryer Model no.lde9304ace
HI,
Please CLIcK HERE all the steps are given including pics to install a belt on your dryer.
Jul 23, 2008 | Maytag Dryers
Dryers Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
