How can I adjust the screen size? I could not find picture menu to resolve this problem
4 Suggested Answers
ArnelM
  • 153 Answers
SOURCE: Picture size doesn't fit the screen I tried to
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Posted on Dec 30, 2009
TODDAS
  • 431 Answers
SOURCE: picture does not extend o bottom of screen
You have to have Remcon remote to get into the service menu.
Posted on Nov 24, 2011
SD Tech
  • 14553 Answers
SOURCE: Samsung TV pic size problem- I've tried pressing -menu -picture mode -screen adjustment Then tried all different screen sizes but to no avail
If the remote has a Format button try that---If you Play a DVD etc do you have the same issue? If not and using a box--it may have in its menu adjustments.
You could also check for a service manual or ask the maker if the set has a hidden menu (tech menu) where adjustments for this can be made if the issue is exactly the same on all inputs.
Posted on Dec 16, 2012
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Nov 12, 2013 | Cell Phones
Dec 16, 2012 | Televison & Video
Zenith tv picture is larger than screen
Hello
There are Horizontal and Vertical size controls behind the back cover that need to be adjusted using a hand held tool. This adjustment requires a trained tech. High Voltage from the set is dangerous.
However, there maybe some limited controls that may help through the on screen menu.
To get into the setup menu, you need the original Remote that came with the TV.
Hold the Menu Key down until a box appears in the corner of the screen, then press 9,8,7,6 Enter. this takes you to the service menu. Just scroll through the items to find Horiz Size and Vert Size.
Good luck
Dec 30, 2009 | Zenith H32G48S TV
Picture too big for screen.
go to menu and adjust screen size(picture size)
Jul 29, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Picture too big for screen?
There is a service menu that controls such things as picture size etc. and that's likely where adjustments have to be made.
Unfortunately I'm not sure how to get into it. That information should be here somewhere, search for your tv brand and "service menu".
Jun 30, 2008 | RCA 20F410T 20" TV
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Picture too big
The horizontal size adjustment is in the service menu only. I would suggest someone who knows the code to do it for you.
Jan 25, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
