Question about Cuisinart Coffee Makers & Espresso Machines
Cuisinart coffee grinder wont work - Cuisinart Coffee Makers & Espresso Machines
SOURCE: Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Posted on May 21, 2008
SOURCE: cuisinart burr coffee grinder
The best solution I have was referred to me by a mate of mine who services commercial coffee machines.
Step 1. Remove the base of the grinder... this is actually the hardest aspect of this task... as there is one tamper-proofing screw... if you can't get the correct star-hex screw driver I recommend drilling the screw out.
Step 2. Once the base is off you will see the main shaft of the grinders motor. The shaft has a star washer set in behind hew nut, the end of the shaft has a slot cut into for a flat bladed screwdriver. Hold the nut with a pair of pliers & you can adjust the shaft positioning (& hence the burr attached to the motor) by about 3mm....
You will need to experiment to find the correct level of fineness as you require.
If you need further information send me an e-mail as I'd be happy to forward more detailed instructions.
Good Luck.
Cheers.......
Dave (dave@kingkiwi.f9.co.uk)
Posted on Nov 04, 2009
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
SOURCE: coffee grinder not working
My burr grinder also stops if the ground spout (where the coffee shoots out) is clogged. I use my grinder for an espresso machine so i always have the setting on the finest and so with the oils and the fine grind it clogs this spout pretty often. I"d check yours out too (ie remove the coffee ground bin and you can see the spout. If it is clogged uplug the machine and take a tooth pick and un clogg it. Don't jam the tooth pick in there to deep you don't want it to get shuved into the grinder wheels.
Posted on Feb 07, 2010
  • 3 Answers
SOURCE: cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Posted on Mar 13, 2010
Hi, Using this Cuisinart Conical grinder is awful. The static makes the coffee stick to everything and makes it difficult when you are using this. Any suggestions would be greatly appreciated.
The only thing I've found that will work for this problem, which I certainly agree creates a mess, is to let the grinds sit for just a few minutes before opening the receiving cup. Especially in winter, this will give the static charge a chance to dissipate. A few minutes won't kill your coffee's taste, but it sure will lessen your cleanup!
Sep 14, 2013 | Cuisinart Conical Burr Coffee Grinder
My Cuisinart DCG-12BC coffee grinder, the bowl is stuck on the motor base. It works and turns, but it will not come apart to be able to clean it. Please advise.
.... mine stuck after "first" use ... solution ... took it back to the store, got a refund, bought a Mr. Coffee Model IDS77 which was $11. cheaper, has automatic grind settings and a superior bowl arrangement... Then I put Cuisinart on my list of DO NOT BUY ... anything can have problems, but something obviously this chronic should be handled better by the manufacturer ... it should have been taken off the market and fixed ...
Aug 27, 2011 | Cuisinart DCG-12BC Electric Blades Grinder
Cuisinart coffee grinder keeps clogging
Feb 06, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grinder-brewer coffee maker
Use the bursh that came supplied with the coffeemaker to clean around the exterior of the motor area, underneath the grind basket. Make sure the chute is clean as well.
-Tha Mp3 doctor
Oct 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Mar 15, 2007 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
99 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
