Question about Kitchen Appliances - Others
My 4 slice duo lit toaster "toasts" the upper half of my toast more than the bottom half. Center elements glow red after about a minute while the end elements take about two minutes to glow. Thoughts?
  • 3,382 Answers
It should not work that way take it back and get a new unit. I am assuming it is operating on the correct voltage. If it is a 220V unit on 120V it would work that way.
Posted on Dec 31, 2016
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
  • 11800 Answers
SOURCE: Left-hand section only toasts on one side
The heating resistor on the left side has shorted with the case. Since you don't know very much on electrical equipment (to fix it you would have to open it, remove the shorted piece of wire, reattach all and insulate them properly) and the price of a new item is low, just buy a new one and discard this one. You shouldn't use it again, under no circumstances - if you're unlucky it can kill you.
Posted on Oct 03, 2009
Testimonial: "Thank you very much for the information. I will be heading out to buy a new toaster. "
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
SOURCE: krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Posted on Apr 13, 2010
espressonist
  • 1711 Answers
SOURCE: How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Posted on Aug 20, 2010
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
Krups toast supreme 4-slice toaster stopped working
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Not toasting evenly
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Remember that the four in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Mar 26, 2010 | Dualit 31210 3-Slice Toaster
Recently it has taken longer and longer for pieces of bread to toast. Additionally, the plug seems unduly warm. Do the elements need replacing?
Good Luck
Jan 10, 2010 | Dualit Vario 3 Slices Toaster
Inherited a Dualit Vario 3 Toaster without instructions
Good Luck
Nov 12, 2009 | Dualit 31210 3-Slice Toaster
Our 4-slice toaster (model 4cbc) is only toasting part of one side of the toast, as if a heating element has burned out.
Good Luck
Aug 05, 2009 | Dualit Kitchen Appliances - Others
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Kitchen Appliances - Others Logo
137 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
