Question about GPX Audio Players & Recorders
How do I create a playlist on my gpx 863s? - GPX Audio Players & Recorders
How can I get the songs I sync to my mp3 to play in the order I choose and not group all the songs from the same artist together?
Depends on device and software. In general you can make playlists where you can select the sort order. Playlists are very flexible, at least on my iPhone and in iTunes. Another idea would be to copy all the song you want to sync into a new folder, then edit the detailed info for each song to set the track number for each song to be in the order you want. Possibly you can create a compilation out the songs but again, I think the compilation would need the songs track number to be in your prefered order.
Dec 03, 2014 | GPX Audio Players & Recorders
How to do playlist on the s100
Hi, You can do play list from your PC. By connecting your MP3 player to the PC through Usb cable..
Things You'll Need:
* Computer
* Media player
* Digital music files
Creating a playlist on your computer is an easy way to organize your music. Playlists allow you to organize music by different artists or different genres. More advanced playlists can even sort your music based on when it was added or how often you play a particular song. Creating a playlist is an easy task regardless of the media player you use to play your music.
Determine what songs you would like to add to your playlist.
Create a new playlist in your media player. Depending on your media player, this step will vary. There is usually a "Create Playlist" button that you can click to create a new playlist. In iTunes, this button is on the bottom lower left corner. In Winamp, click the "View" menu and select "Playlist Editor".
Select the songs that you want in your playlist from a new Windows Explorer window. If you are using a Macintosh computer, select the songs from a new Finder window. You can hold down CTRL to select multiple tracks. Drag and drop these selected songs into the new playlist you have just created.
Save the playlist you have just created. Most media players have a "Save Playlist" button. Other media players such as iTunes will automatically save the playlist for you when you first create it. In Winamp, click the "Manage Playlist" button in the bottom right corner. In the following context menu, click "Save Playlist". Name the playlist whatever you want and then choose where you want it to be saved.
Have a nice day....
Feb 19, 2011 | iRiver E10 Digital Media Player
How do i create a playlist?
how do I down load on to my gpx ml660 Digital media player
Dec 26, 2009 | GPX MW3836 MP3 Player
How to seperate music files. I would like to add individaul playlists. Instead of all songs grouped together and you have to shift through all songs to get to the one you want.
Hi shannitar,
You can try placing the music files in different folders. If your mp3 player supports playlists (which it should), then go to the folder where your music files are kept, use ctrl+ click to select those you want to add to the playlist IN THE DESIRED ORDER, then right click and choose "creat playlist". A .pla file (or any other extension) will be created, which you can now play on your mp3 player.
Oct 17, 2009 | GPX Audio Players & Recorders
Deleteing music from GPX mp3 player
open the gpx file and manuallt delete take the battery out before you connect to the computer it might cause an error and wont sync up with a media player
Apr 04, 2009 | GPX MW3836 MP3 Player
Want to change the order of songs so I can play them in order
Find the instructions for the unit, create a playlist, then play the playlist.
Mar 05, 2009 | GPX MW-3847 MP3 Player
Random play feature
Try going in to your player and creating a playlist.Go into your player through " My computer". When it brings up your main folders, right click on the music folder and click create playlist. All the songs you have will be bunched into one playlist.
Then while your player is paused, hit mode, scroll to the playlist you created and then set it to random play from there. Should work.
Dec 29, 2008 | GPX ML648B MP3 Player
Wont copy songs to mp3 player because of write protection
please see the info here
http://www.gpx.com/store/p/334-MW238P.aspx
please info if it helps..
Nov 19, 2008 | Audio Players & Recorders
77 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
