Question about LG Televison & Video
Hi I have a problem with LG 47" Led power supply EAX64905501(2.2) it switches on and back to standby, the power voltage 3.5V is there but doesn't give off 12V and 24V doesn't switch on the backlights.
  • 195 Answers
The unit is shutting down due to a component fault. Do you have the service manual and software ?
Posted on Jan 06, 2017
  • 3866 Answers
SOURCE: power supply squeal magna.26MF605W/17
You need a higher capcitor as far as voltage if you got a sag, A power supply making noise is not a verry good sign period and this is dcomming from a eletronics engineer! There is something wroung with the circuit. I would sugges changing out the power supply unit due to a possiable problem with the rails.
Posted on Jun 17, 2009
  • 1077 Answers
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD
Posted on Apr 23, 2010
SOURCE: ILO LCD, Power supply issue, MLT169B. 24v output is dead.
I want to know R3 value
Posted on Dec 27, 2010
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
Lg 42ln5400 no power
Standby light voltage (3.3VDC) is generated from the main digital board. If there is no standby light, means this voltage is absent. Check it, Replace the main digital board, if needy.
Feb 13, 2017 | LG Televison & Video
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
My OCosmo 47" LED TV will not turn on. I already replaced the power supply board, now what?
And all the Capps are down on the rest of the boards also it a switch mode power supply so make sure it's switching
Oct 07, 2016 | Ocosmo Ocoo 47-Inch 1080p 60Hz LED HDTV...
Audio is fine. Why did picture suddenly go black?
The board that controls the back light for the screen is called an inverter board. Sometimes, depending on the model , the inverter is combined with the power supply board. Go here to find the parts
Feb 02, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Red light power button just flashes slowly. Blank screen, no back lights. Performed flashlight test and can't seen menu.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 30, 2015 | LG 47 47LK530 LCD TV
LG 32LB530A Tv sound ok faint picture Led backlid off
Back light led driver or the led array is faulty. check and confirm the voltage to the led back light from the power supply. normally 35V to 100V according to the brand and model of the tv. Check the voltage if the voltage is somewhere around the above mentioned voltage the then the tv have problem with the led array behind the screen . If the voltage is missing then the led driver is faulty. Normally the led drivers is found integrated to the power supply board. If so then you have to replace the power supply board as a whole.
Oct 10, 2015 | LG Televison & Video
How can I fix my 42' lg it is stuck in standby mode.
I had the same issue with my 47' LG. If it's under warranty just have someone look at it. Mine wasn't so I took off the back panel, checked the power supply for the correct voltages coming out, which were unfortunately were correct. Which only left the main PCB, which was more expensive than a new TV and could only be installed by a "technician." However, the blinks could be a fault code. Here's the link to my question. have 47 LG LCD TV 47LD450 AU and when try to turn it on the red LED...
Jun 17, 2014 | LG 47LD450 47 in. TV
My Sony Bravia HX8/46 will not turn on, I check all the power going to it and it all works. Is there something I can do?
Is the standby led on the front lit. If not likely the problem is with power supply. If the standby led is on does it go off when the power button is pressed? Does the led blink. If so count the blinks and get back. The power supply provides an standby voltage to the main board. If the standby led is lit then this voltage is present. When the power button is pressed the micro sends a turn on voltage to the power board. Normally the power supply will respond and all other voltages needed to operate the set will come up. if a component is shorted the micro will not turn on the power board and will usually give a failure code via the standby led.
May 31, 2013 | Televison & Video
Samsung HC-R4755W 47 in hdtv will not come on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
May 27, 2017 | Samsung HC-R4755W 47" HDTV
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Open Questions:
I have a LG 50 LCD TV Model: 50LN5700-UH that has a black screen. There are a couple of things I have tested and replaced. First off there is audio but just a black screen. I turned off the lights and looked for signs of back lights. When I did this there were no visible signs of lights. In addition, I did the flashlight test. Which showed visible signs of lettering on the screen with the flashlight. Which if I understand correctly it may determine that the T-Con board is functional. I ordered additional LCD's from Shop Jimmy and replaced the bad sticks. About half were replaced. I reassembled the TV and I am still getting no video, but I still have audio. However, this time all the LCD's are functioning so now the screen is still more grey than black because of the working LCD's I replaced. What voltages and at what points should I be testing to narrow down the problem, or what other problem-solving technique should I be testing? One other thing I should mention is there no visible signs of swollen capacitors or any signs of burn marks. I am 99% sure I connected all of the cabling up correctly, not 100% since this was my first attempt but I am a little less confident I put the filters in the correct way. I had the TV disassembled while I was waiting on the LCD's to ship and when I re-assembled I was less confident if I picked up all 3 or 4 filters and set them down, or if I make have flipped the filters to keep the circuit board on the front cover from being damaged. Hope that make since.
Mar 16, 2018 | LG Televison & Video
Televison & Video Logo
121 people viewed this question
Computer Repairing
Computer Repairing
