Question about Crafts & Hobbies
My OO Flying Scotsman engine refuses to run. Keeps shorting out. Any tips or ideas?
I am running two tracks with sidings controlled with two Hornby controllers. Other engines appear to run OK
  • 56 Answers
SOURCE: P0336 Code
The code P0336 is crank shaft sensor performance code.The sensor could be faulty and not picking up a good signal.The after erasing the code,the problem still exists ,so it is then a pending code and when you shut the car off and restart it the code reappears.Just another idea here ,if you have not had a tune-up recently(plugs,wires,airfilter,etc.)you could get unwanted codes and your engine will not perform as it should.This could cause poor gas mileage as well.John.
Posted on Mar 07, 2009
mecanica03
  • 911 Answers
SOURCE: SC 400 engine light and track light on-but engine runs great
to reset any malfuntion in memory , disconnect the negative battery terminal few minutes
Posted on Apr 15, 2009
Molson02536
  • 3854 Answers
SOURCE: idle is too low, car dies, engine runs fine
An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The car computer or ECM (electronic control module) receives information from various sensors and will output signals to adjust the IAC motor in or out to adjust engine idle speed by controlling engine idle air.
An IAC motor is highly susceptible to carbon and coking build up; if an IAC goes too long without cleaning it can cause stalling and poor idle quality. Some cars are designed with a large vacuum transfer hose that connects the intake manifold to the IAC (idle air control) motor. If a broken or dilapidated these vacuum lines can cause the engine to lose vacuum which will allow the engine to run rough and die.
Inspect all engine and accessory vacuum lines to look for missing, torn or dilapidated lines and replace as needed. To check the IAC motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the IAC should move in or out.
If the IAC motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the IAC motor is removed clean (use aerosol carburetor cleaner) the passages the IAC uses to control idle air speed.
Good luck and hope this helps
Posted on May 08, 2009
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
Delage guy
  • 167 Answers
SOURCE: 1998 camry 5sfe engine, surging at idle
Check for air leaks in the vacuum pipes in and around the inlet manifold, they have a habit if going brittle and splitting.
Another possibility is the temp sender , if the ecu thinks the engine is too cold it will compensate causing the engine to " hunt". This can be something as simple as a worn radiator cap seal letting air into the cooling system and tricking the sensor.
Hope this helps, Marshall
Posted on Apr 29, 2010
Takeuchi mini digger tracking problem
Pressure valve? does it only do it to only one side? Left or right. The reason you move both tracks with the bucket running is because you relieve pressure. One side is free wheeling, As they call it. I work on cars, But also have done to many hydraulic components. You have a pressure control valve that is bad.
Jul 10, 2016 | Mini Cars & Trucks
We are running the legacy control system. Our layout has roughly 200 feet of track. There is one stretch about 2 foot long that the engine seems to lose its signal. Imparticular the union pacific big...
Check your track voltage with a multimeter. If you get a lower reading at the spot that causes the problem, add a feeder wire to that point.
Oct 04, 2013 | Crafts & Hobbies
My scotsman cm universal service controller keeps shutting off and refrigeration light blinks twice. But there is plenty of freon. What is the problem?
Most likely water inlet valve. When they get stuck open water continuously flows in preventing it from from freezing and therefore the controller thinks it's running and not getting cold enough so it cuts off on refrigeration. It will cut off on water if no water is detected.
Nov 06, 2012 | Scotsman Ice Maker 600LB CM3 30inW...
Hello. I have bought a Hornby HM2000 controller and slave but it came with no instructions. Search the web to find a download with no success. Have you any ideas. Basic operation is straightforward but...
Hi Roger and welcome to FixYa, I am Kelly.
I went through the same searching drill you just did and came up with the same negative results.
The product code is R8012 and the model number is HM2000. (Forum searches also)
You are going to have to contact them here:
http://www.hornby.com/building-a-model-railway/hvr-support-form.html
or here: http://www.hornby.com/contact-us
Make sure to include the model number and the product code on the form.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Toys
Electrical Problem???
Try having the charge system/ alternator load tested, if thats ok have the ignition module and coil pack tested at a local parts store.
Apr 21, 2010 | 1997 Jaguar XJ6
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Crafts & Hobbies Logo
103 people viewed this question
Top Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
