Question about HP Vs17 17" LCD Flat Panel Monitor
My monitor internal speakers have a problem --
-- the sound is similar to an echo chamber. How do I fix this?
    Master:
    Sergeant:
  • 226 Answers
Look in the control panel there should be something there for the sound, it should be something like a sound effect manager open it and disable it
Posted on Jul 20, 2009
I have a Swisstech 15"
Hi michael_b975,
Please check the audio settings and disable the echo mode , or anything similar to that , if there is an option for default settings , please choose that option so that you would have normal sound.
May 10, 2011 | Televison & Video
My television sounds like it is echoing very badly how can i fix this?
your inbuild speaker might have burned out,,,check tv with some external speaker if possible....other wise you have to take it to the tv reparing shop or centre
Oct 20, 2010 | ViewSonic MB110 Monitor
The speakers sound like an echo and you can't understand what is being said with everything being distorted. The monitor has not been in use for a few months and everything else is working properly, but I...
Have you checked the sound with some other speakers or a headphones.
If the sound is still like echo try adjusting audio settings not thru My Computer - audio, but try finding a software that comes with *********** board/sound card. I suppose the sound is some AC97/Realtek compatible card, so you should looking in your program files under Realtek into WDM and run the Audio Control Panel or Sound Manager (whatever you find). Adjust the sound effects to NONE and use some normal enviroment (other then echo/cave/big hall).
May 22, 2010 | ViewSonic Computers & Internet
Sounds sound like an echo chamber
1. Click Start, click Control Panel, click Hardware and Sound, and then click Sound.
2. In the Sound window right-click your Speakers and select Configure Speakers.
3. Follow the on-screen setup, and Test the available configurations.
4. Indentify whether or not one configuration appears to have less of an “echo” than others.
5. If the issue is resolved by modifying the configuration then you do not need to do anything further
May 18, 2010 | E-Machines eMachines Desktop PC
When I try to use both internal and external speakers at the same
Check your plugins to make sure the external speakers arren't plugged into the rear surround plugin. That usually makes an echo sound. Also try adjusting your equalizer. Right side of eq should be up higher, then middle should be a little lower, and left side of eq should be about the middle setting. If this works or not let me know
Jan 17, 2009 | Samsung LN52A650A LCD TV
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
I have an acer laptop and i have an echoe in my sound... im not sure what the problem is. there is an internal mic i believe. help please! lol
Try right clicking on yout Volume Icon in the system tray (where your clock is). Click on Open Volume Control.
Make sure you have some audio playing, then just go through each channel and mute each one, 1 by 1 until the echo has gone.
If that don't work, then again, right click on Volume Icon in Tray, click on Adjust Audio Properties, then under speaker settings, select advance, then choose Desktop Stereo Speakers, under the Speaker Setup Options.
One of those should work. If it is your Mic causing the Echo, then you would get loads of feedback if you whack up the volume. If you don't get the feedback, then it's more then likely the Speaker Setup or some Sound FX is enabled through your Sound Card Software.
Dec 02, 2008 | Acer 90.00012.30B Computer Speakers
HP vs 15 the built in speakers echo
Do you have a microphone? If you do, and it is near the speakers, it will echo a lot. Also, check your soundcard settings. If there is an option for room ambience or environment effects, make sure you have them disabled.
Jul 14, 2008 | HP vs15 15"LCD Flat Panel Monitor
Sound problem
What motherboard are you using? Does it have a Volume effects changer option on its Sound Card? Try changing that option first.
Sep 14, 2007 | JBL CREATURE II Computer Speakers
Sound problem
Sounds silly but, try muting your built in microphone, because i'l bet, the mic is picking up the sound from yours speakers and causing the echo. That's wot i've found on a few occassions. Other than that, check sound and video drivers by click Start>Run, then type in 'dxdiag' (without quotes) this will run a diagnostic on audio and video. Please rate this solution
Nov 09, 2006 | Toshiba Satellite P30 P35 Series Notebook
HP Vs17 17" LCD Flat Panel Monitor Logo
161 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
