Question about Amana Refrigerators
Amana fridge, AS2628HEK fluctuates in temp.Keeps repeating. Replaced the front display board, has been on lock for some time, ice and water were not operating, now it works again but temps not stable?
Len lambert gold coast QLD
  • 50 Answers
Replacing the front display board will not do anything other then tell the main control board what you would like to do. The control board that controls the operation is in the fresh food section up in the console area. What do you mean by temps not stable? Refrigerators do fluctuate in temperature especially after defrost.
Posted on Dec 08, 2016
How do you fix icing sensor error (ER IS) on an LG lfx25974st Fridge?
My lg fridge keeps beeping saying the freezer temperature is fluctuating
Jan 20, 2015 | LG Refrigerators
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana refridgerator, BRD18V13, and the ice maker stopped making ice. What's wrong?
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Amana Refrigerators
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Water reservoir in bottom back of frig keeps freezing up.
Too cold in fridge if it is freezing is your milk or other items freezing. Check temp in fridge with a good thermometer.
Nov 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana bz22rw fridge temp fluctuates & is a little warm - freezer is ok should i replace the fridge temp control or the damper
Temp control = controls run time of the compressor and temp of freezer.
damper and cold control = control how cool the fridge is...
also check you fan speed and air flow to the fridge.
Sep 19, 2009 | Amana Refrigerators
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Front Door Amana Computer Door Pad Changes on its Own? Amana ARS2667BW
it could be the power outage. electronics are very sensitive, it could be damage by just static electricity alone. i suggest that you can plug it to an automatic voltage regulator with a time delay so that it could save your unit after a power interruption.
regarding your problem now, it could just be a touch pad problem. maybe that is the only part fried by the surges. i assume the refrigerator cooling performance was not affected. only the touchpad panel is affected.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
