Supply of relay av502a konzert? - Audio Players & Recorders
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Konzert AV502a (500watts per channel)
Your listening habits should not have you pushing the volume level so high that the amplifier will distort, as it is DIRTY wattage that kills speakers. A more powerful amp will distort less if pushed to a given loudness.
BTW: the specs for the amp and speakers are not really what they claim. Since the same company made them the numbers are probably equally wrong. Don't sweat it and don't turn it up so loud that it distorts.
Posted on Dec 29, 2010
How do i fix my konzert amp after i change the ic
What is the problem? You can contact me at my website, audioserviceclinic.com. You can contact me there.
Apr 09, 2015 | Audio Players & Recorders
SIR,,i have konzert av 302 no sond but there is power please help thanks
There can many causes. You may have an amplifier damaged, power supply issue, on and on. If you are interested in having your Konzert repaired, please visit my website at audioserviceclinic.com. You may contact me there.
Mar 30, 2015 | Audio Players & Recorders
Why does my Konzert AV502A have no sound output?
You don't give us much to go on. What happened last before you discovered your amp had no sound? Did the speaker wires cross with exposed metal? In other words, did you short out your amp by touching the negative speaker wire with the positive speaker wire? That will "Fry" your unit. Did you check the fuse? I assume you have a good power cord that is properly plugged in. Does your amp light up when turned on? What other issues can you tell us to give us more clues so we can help you?
Feb 20, 2015 | Audio Players & Recorders
Konzert amplifier av 302
200 watts is the output, home use or commercial? not a good amp to run at its max as it has a low reserve headroom. for home use 100 watts rms is more than enough.
Mar 08, 2014 | Audio Players & Recorders
Konzert amplifier has a problem with the audio, it goes on and off how to fix it?
if the relay keeps ticking it certainly means the relay senses an overload or a short circuit in the outputs(speakers). pls. check your speakers, tweeters connection. if you have another amplifier try your speakers if it will be working fine. be sure your speaker wires donot touch each other. try playing at low volumes settings.
May 30, 2013 | Audio Players & Recorders
Just asking for a right speakers for konzert 502a
What actually is Right is for you to decide:
These will be dependent to what you intend to use.
If these unit will be used for Karaoke , suggestion could be
using Single 15" Konzert Speakers for each channel or
Dual 12" Konzert Speakers for each channel.
But if you intend to use it in a small room , you can visit the
showroom in which speakers are connected to it, to have your
final decision.What may be best for others may not be the one
you choose.Listen and feel what you like .
Have a nice day!
Nov 03, 2012 | Audio Players & Recorders
Konzert AV502a (500watts per channel) + Konzert 600 watts speakers Will I not have problem with this setup? I heard that my amp should have higher wattage than my speakers.. Pls advise..
Dec 29, 2010 | Audio Players & Recorders
I have a konzert amplifier av-502 that has two burnt resistor r130r and r130l. could you please let me know the value of the said resistor thank you very much.
Is it the resistors near the relay? that would be 10 ohms. You may replace it with a higher wattage (like say 5 watts)
Aug 02, 2010 | Audio Players & Recorders
100 people viewed this question
 Grubhead
Grubhead
